View Poll Results: What's the variant of your Vios?
- Voters
- 597. You may not vote on this poll
1.3J
86 14.41% -
1.3E
278 46.57% -
1.3G
55 9.21% -
1.5G
117 19.60% -
1.5 XX
4 0.67% -
1.5S
2 0.34% -
1.5SE
5 0.84% -
I don't own a VIOS.
50 8.38%
Results 11,491 to 11,500 of 11542
February 12th, 2022 12:41 PM #11491
Google told me the abs light can be reset by buying a special cable, tapping it to something on the car I forgot then a series of steps that includes stepping multiple times on the brake. If that steps are true then it will be easier and cheaper to pay someone to do it.
Sent from my ONEPLUS A5000 using Tsikot Forums mobile app
- 52,523
February 12th, 2022 01:35 PM #11492
- Jul 2009
- 2,618
February 12th, 2022 06:50 PM #11493
February 12th, 2022 06:52 PM #11494
I think pwede na sa 4k considering Cebu pa. 7k total for clutch parts and labor good for about 70-80K kms, can't complain na. Pero thinking about it now, parang mas gusto ko na mag auto gearbox na lang, ATF change is an hour job rather than a day job for clutch change. And doesn't make a huge difference din sa final expenses. Huwag lang talaga magloko
February 12th, 2022 07:05 PM #11495
Unfortunately for you, Doc, I'm in Cebu Actually got a printout of everything they've done just like sa casa. Going back to this shop in the future for sure.
Using my OBD scanner, the fault won't go away even after replacing the faulty part and doing a re-scan. You have to do a reset (via the OBD scanner) and then you can try scanning again, thereby making sure the faulty part is returning the correct response.
I really feel that some shops make a big business out of it and charge customers excessively for just running the scanner. My OBD scanners are running all the time in both our cars, I might consider charging myself for it also
BTW, I got my first scanner at Shenzhen's Electronic City for about 1.3k. 2 years later I got the 2nd one from Shopee for just 1k. I think China and Shopee is one and the same? hahah
- 52,523
February 12th, 2022 09:56 PM #11496
February 12th, 2022 10:17 PM #11497
I actually got curious and it seems nasa ilalim lang port nya at exposed na? All I have to do is buy a scanner and connect to it. Also there's a learning curve on how to use it. Maybe Google could help on that part.
Update: found the port, all I need now is the scanner.
Can you guys recommend a scanner? I heard there's a Bluetooth version.
Sent from my EB2103 using Tsikot Forums mobile app
February 12th, 2022 10:18 PM #11498
Can you link the OBD scanner from shopee? Or maybe words I can search? OBD 2 ba ang vios? Mine is 2nd gen.
- Jan 2008
- 4,726
February 12th, 2022 10:45 PM #11499
- 52,523
February 13th, 2022 12:16 AM #11500
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
