View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 11,411 to 11,420 of 11542
August 29th, 2020 02:21 PM #11412
if you want to go in the other direction...
going towards orthopedic
madami din tindahan kaliwa kananLast edited by uls; August 29th, 2020 at 02:26 PM.
August 29th, 2020 02:30 PM #11413
kung ako i'd skip all those shops until sa may carryboy (macopa st,)
sa tapat ng carryboy may mga tindahan sigurado meron ung hinanahap mu
- Sep 2020
- 7
September 2nd, 2020 12:07 PM #11414hi po my unit toyota vios 2009 1.5G ATM meron lang ako itatanong saan po kaya nka locate ang vechicle speed sensor? may lumabas sa dashboard na check engine iniscan ko bu using obd2 scanner ito po ang lumabas sana may mka sagot ng tanong ko tia
Sent from my ASUS_I001DA using Tapatalk
- Jan 2008
- 4,726
September 2nd, 2020 03:00 PM #11415
September 3rd, 2020 12:42 AM #11416
nung gumamit ako ng obd sensor gamit ang torque pro. same tyo ng nadetect, pero nung pinascan ko sya sa shop mismo. 3 yung na detect. p0500 at c1401, c1402. ang reco ng unang mekaniko, paltan din yang speed sensor(P0500). ang ginawa ko pinataltan ko ung 2 abs sensor sa front. ako na nag DIY. Ayun ok na ulit, Eto nga pala yung Diy video kung paano ko pinaltan
TOYOTA VIOS 2ND GEN How to Fix C1401 C1402 P0500 Error Code | ABS HANDBREAK CHECK ENGINE - YouTube
- Sep 2020
- 7
September 3rd, 2020 11:04 AM #11417
- Nov 2009
- 3,484
September 3rd, 2020 11:15 AM #11418Ipa scan mo ulit sa shop libre lang un para ma identify specific speed sensor. Apat kasi yan, ang alamko assembly hub yung rear.
C1401 - Malfunction in rear speed sensor FR circuit
C1402 - Malfunction in rear speed sensor FL circuit
C1403 - Malfunction in rear speed sensor RH circuit
C1404 - Malfunction in rear speed sensor LH circuit
P2.8k bile ko replacement hub some 5yrs ago
September 3rd, 2020 11:53 AM #11419
Ang sabi sa kin nung mga mekaniko nsa baba daw ng transmission side. hndi s kin n pin point kung saan exactong location pero check mo ung pic. yan ung pinapapaltan sa kin pero di ako pumayag kc sobrang mahal kung tatlong pyesa ppltan tpos idadamay pa nila yung sa likod na wheel hub na may abs sensor. tpos di nman yun yung problema. siguro mas maganda kung may mura kang mapapascan na gamit ung tlgang nakakadetect ng abs error. pa scan m uli. yung scanner na ginawa sa kin sa laptop nakaconnect. nadetect 3 error. pero sa torque pro 1 error lang.
You can visit my YT Channel HERE for basic CAR DiY Tips
- Aug 2019
- 77
September 3rd, 2020 12:59 PM #11420hello po.
san po kayo nabili ng shock? parang matigas na ung sa akin.
every kelan po ba pinapaltan ang shock?
THank you!
suzuki #2... kahit malayo... heh heh.
Car Sales Data (2023)
