View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 11,371 to 11,380 of 11542
- Aug 2019
- 97
August 15th, 2020 03:59 PM #11371theres a difference in sized. it means affected ang acceleration.
ang naging observation after the changes was slow response sa takbo nung car. i mean example was from low speed then mag overtake apak sa gas mahina ang responce nang car at ang takbo almost full apak na siya. naka drive ang gear didnt used manual plus minus. anyway no chances already to back to stock rim and tire. kaya need to find ways to get back the car performance. may magawa pa ba ang casa for this. may maa adjust pa ba in terms of acceleration response. or throttle responce. not sure what will do. baguhan lang. pinalitan lang ang golong kasi steel rim dati na 175/65/R14. kaya nung nag palit ang nilagay was 195/55/R15..
im posting this here hoping to get advised not to be make katatawa or matawag na tanga or know knowledge. accepted naman na baguhan lang. kaya nga nag join sa group para may makuhang knowledge not the other way around. dont have much knowledge in mechanical and car areas. kon sa electrical pa to sigoro no need to post it here i cant managed electrical issue without any problems.
August 16th, 2020 05:32 AM #11372
sakin lang, pag gusto mo additional power ay palit ka ng auto. unless gusto mo ikeep yun car. pero if gusto mo ikeep yun car mo for sentimental reason (cant see any other reason for keeping a vios, altis or any ubiquitous car).
eto magagastos mo para additional 12hp ..
Speedlab - Vios/Yaris Dual VVTI power package
Speedlab... | Facebook
eto naman plus 40hp
SpeedLab Supercharger Systems Toyota Vios/Yaris - Speedlab
Sent from my RMX2020 using Tapatalk
August 16th, 2020 05:35 AM #11373
[QUOTE=wenz_vios 1.3 x;3195301]theres a difference in sized. it means affected ang acceleration.
[/QUOTE
not really sure why significant ang loss of hatak ng size change mo. eh stock tires ng vios E variant ay 185 / 55 / 15 lang naman din
vs your new tires 195/55/15
Sent from my iPhone using Tapatalk]
- Jun 2011
- 1,077
August 16th, 2020 07:38 AM #11374Ilan PSI ngayon ang tire pressure 195/55/15 na goma?
Puwede try taasan ng 2-3 psi. Para maging 32-35 psi. Matalbog nga kang ng kaunti. Effect ng mataas na PSI ay bawasan ang rolling resistance at mabawasan ang contact area, para mas madali paikutin ang gulong.
Subukan din mag Petron Blaze for 1 full tank.
Overspeced ang Blaze sa normal engine. Sa experience ko may difference sa underpowered na sasakyan ( or baka placebo effect lang hehe). Pero iyon maganda masubukan muna Blaze 1st hand kung may effect.
- 52,700
August 16th, 2020 10:17 AM #11376
- 52,700
August 16th, 2020 12:04 PM #11377sometimes,
an engine might have been programmed to run adequately on ron 91,
but in truth it was initially designed to, and run better, on ron 95...Last edited by dr. d; August 16th, 2020 at 12:06 PM.
- May 2016
- 546
August 16th, 2020 01:10 PM #11378Only reason I can think of is increased rolling resistance. More rolling resistance means more power needed to propel your vehicle.
Your new tires might be of lower spec than OEM, plus the wider rubber hence higher rolling resistance.
- Jun 2011
- 1,077
August 16th, 2020 01:42 PM #11379[QUOTE=Egan101;3195412]Increase in RON rating will not improve performance. Perception lang yun at extra gastos. [QUOTE]
Oo nga, tama.
Kaso hindi RON ang habol ko sa Blaze. Iyong higher energy density ng 100% gasoline, compared sa Ethanol blend. Plus iwas Ethanol side effects. (Though equipped ang modern fuel systems para sa Ethanol, old school lang siguro kung kaya iwasan Ethanol) (Plus iyong supposedly better additives at detergents ng premium fuel). Plus Euro6 less pollutants
