View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 10,441 to 10,450 of 11542
August 6th, 2016 08:58 AM #10441
May nabibili ba shocks boot para sa 1st gen vios? Sabi kasi mechanic wala daw, sabi naman nung isa pwede universal nga lang. Thanks
Sent from my E5553 using Tapatalk
August 6th, 2016 09:54 AM #10442
Naputukan ng goma vios ni wifey sa front right. Kaya renewal (all tires) talaga nangyari. Whew! Unexpected expense.
Sent from Zenfone2
- 52,731
August 6th, 2016 10:36 AM #10443
August 6th, 2016 11:06 AM #10444
Wala naman ako nadaanan na anything like manhole, pothole or gutters. Pinalitan ko na lang lahat para may peace of mind. Pansin ko parang malutong na rin yung luma. Eh magkakapatid ang mga yun, so anytime posible rin na pumutok yung iba. Sa speed na 100kph I noticed kumiling sa kanan yung takbo and then yun nga pumutok sya. Buti walang damage yung rim.
Sent from Zenfone2Last edited by leinahtan; August 6th, 2016 at 11:10 AM.
- Mar 2016
- 9
August 7th, 2016 12:52 AM #10445hello guys,
I have vios 1.3J manual gear, ang rpm gauge nya ay erratic o fluctuating pero ang makina ay stable naman. Saan kya ang problem? saan ba ang sensor ng RPM sa makina nka kabit ( kung meron) or, is it sense by electrical pulses? saan nka kabit yan to detect the rpm?
Yung check engine light ay di naman nka "on" so it hink di naman sa makina yun. Sabi ng Toyota baka daw yung RPM panel ang sira. I want to make sure kung yun nga dahil bka tanggalin tapos di naman pala doon ang problem.
Any help?
- Oct 2013
- 2,537
August 7th, 2016 01:01 AM #10446kamusta takbo ng tsikot mo? nag aacelerate pa ba pag nasa 4th gear na o steady na ang speed habang tumataas ang rpm? kase kung ganun eh slipping clutch disk ka na...
pero sa tanong mo erratic RPM, mag kabit ka ng OBDII scanner na may real time info, compare mo RPM reading ng instrument panel vs OBDII reader, kung tugma, sensor, kung hinde edi yong panel...
saan meron OBDII reader? sa mga mekaniko siguro, no idea, meron kase ako personal na OBDII reader...
- Oct 2013
- 2,537
August 7th, 2016 01:03 AM #10447
- Mar 2016
- 9
August 7th, 2016 06:15 PM #10448Sir, Salamat sa info. Ok naman ang takbo kahit anong gear. Di makita ang tamang rpm kasi ang needle ay laging magalaw. Now, assuming nakita sa OBDII reader na tugma ang reading, sensor ang possible issue. Ang tanong is saan nka kabit ang rpm sensor sa makina? I tried looking for that, di ko makita. Ang ibang makina is thru alternator wire daw, but I tried removing the socket from alternator and started the engine, gumalaw pa rin yung needle ng rpm. Meaning hindi sa alternator kumukuha ng RPm counter.??
- Oct 2013
- 2,537
August 7th, 2016 09:21 PM #10449good to hear na maayos ang takbo ng tsikot mo at any gear, sana nga sira instrument cluster lang and hindi sira output ng ECU (good ECU input, bad output)
anyways, the crankshaft position sensor daw ang nag compute ng engine RPM...
Engine Speed Sensor Location? [Archive] - Toyota Yaris Forums - Ultimate Yaris Enthusiast Site
August 11th, 2016 12:16 AM #10450
Change is coming...
Sent from my SM-G7102 using Tsikot Forums mobile app
Monk-owned R53
