Results 141 to 150 of 193
- Apr 2009
- 3
April 4th, 2009 09:47 PM #141same problem with my CA310. nabasa ko kasi sa manual na dapat 2 beeps lang and 2 flashes lang dapat yung light but when i press unlock button 4 times beep and 3 flashes sakin tapos pag nilock ko 3 times naman yung beep at 1 flash lang ng lights.
meron pa din bang ibang nakaexperience nito? may problem ba yung alarm ko?
thanks
April 22nd, 2009 08:38 PM #142
June 12th, 2009 01:52 PM #143
July 11th, 2009 12:11 AM #144
Its a 2005 toyota camry. Sigue ill try to remove negative battery terminal and see if ok na.
- Jun 2009
- 33
July 20th, 2009 01:38 PM #145Uhm.. sensha malamang natanong na 'to before pero ang haba na ng thread mejo tinamad nako hanapin hehe..
Anyway, I just got a new Altis a few days ago and it has the TVSS thing as well.. So, does it mean parang keyless entry lang ang silbi nya? so di sha talaga alarm system? It won't alarm pag forced entry or something like that?! Kasi nag assume nako na alarm system talaga sha. I have yet to read the manual kasi.. Inuna ko na ang pag s-stroll hehe.. Sensha kung naulit na yung question
July 20th, 2009 02:00 PM #146
sa revo 2001 meron shock sensor ito, pwede mo pa ng iadjust ang sensitivity nito sa maliit na rotary switch using small flat screrw driver.
July 25th, 2009 09:46 AM #147
Here is the tvss pos from a toyota camry. There is a shock sensor adjuster as seen it the picture.
Replaced this sucker with a cheap alarm and works perfectly.Last edited by Memphis Raines; October 19th, 2009 at 04:31 PM. Reason: pics not available
September 21st, 2009 08:09 AM #148
September 21st, 2009 08:31 AM #149
It has shock sensor actually, but not that sensitive.
Go inside your car and arm the TVSS and wait till the LED flashes, using your hand, slap hard the top of your instrument/panel cluster and you'll be surprise that the horn/alarm/flashing turn lights will all get activated.
I really don't get it when Toyota SA says it does not have shock sensor while it really has one. I even demonstrate it to a dealer when they told me it does not have shock sensor, they were awed when I trigger the alarm by slapping the dashboard centering the instrument panel.
September 21st, 2009 09:04 AM #150
^^^ wow! that's good news! good to hear ma meron palang shock sensor ang tvss. para kasing useless ang alarm without a shock sensor. pano kung may bumangga sa kotse mo then di siya tumunog. eh di bigla ka nalang mashoshock na pag nakita mong may bump na ang kotse.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
