Results 1,361 to 1,370 of 1441
October 17th, 2019 11:31 PM #1361
- 52,731
October 17th, 2019 11:41 PM #1362let me guess...
nawala ang owner's manual, at na-pintahan ang sticker.
at iba-ibang size na gulong ang nakakabit!
apologies to TS.Last edited by dr. d; October 17th, 2019 at 11:45 PM.
- Oct 2019
- 1
October 18th, 2019 09:39 PM #1363Good day po.. May owners manual po ba kayo ng Toyota Revo diesel po.. Salamat po.. Pwede po ba makahingi? wala po kasing manual nabili ko na 2nd hand. Kung hindi po pwede.. Baka po pwede malaman ang required Engine oil, transmission oil, power steering fluid, at coolant po.. Salamat po..
October 23rd, 2019 05:38 AM #1364
The owner's manual recommendations changes on which engine and tire/wheel you have
for 2002 and below:
Tire Size Front Rear 185/80R14 Gasoline 26 psi 34 psi Diesel 30 psi 34 psi 195/70R14 Gasoline 26 psi 36 psi Diesel 30 psi 36 psi 195/65R15 30 psi 36 psi
You may have to adjust tire pressures if you are upsizing or moving to a different load range(e.g. From P to LT tires) even if they are the same load index and speed rating(91S ata for revos ?).
https://static1.1.sqspcdn.com/static...+inflation.pdf
- Apr 2008
- 6,237
October 23rd, 2019 08:38 PM #1365When we still had the Revo, I used to inflate up to 38psi front and rear. Higher inflation means lesser effort to move the car, and the Revo is a very lethargic vehicle. It needed all the help it could get! [emoji23]
Sent from my SM-G965N using Tapatalk
October 23rd, 2019 11:51 PM #1366
- Jun 2017
- 12
November 1st, 2019 03:40 PM #1367pwede po mag request/ hinge po pdf. service manual and or owners manual po ng revo gsx 2.0 1rz gas engine po.. my email address po is odraregnivla*gmail.com ..maraming maraming salamat po
- Sep 2019
- 11
November 28th, 2019 02:07 PM #1368Mga sir, planning to replace my radiator for 1999 revo GL very soon. Ano po ba need ko e note Pag fill ng coolant/ distilled water? My recommended ratio ba or practice namas maiging sundin?
- Nov 2008
- 641
November 28th, 2019 03:49 PM #1369
November 28th, 2019 06:07 PM #1370
It will be better if you will use a premixed coolant so that you don't have to worry about ratio.
Drain it and fill it with running water until it is clear. Close the "valve" then fill it up with the premixed coolant for one or two liters then partly open the drain and wait until you have a clear coolant flowing out.
Close the drain and fill it up fully with the premixed coolant. Don't close the radiator cap and start the car. Wait for about five to ten minutes to make sure that any trapped air will escape.
I hope someone will correct me on this if there's anything wrong.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
