Results 1,231 to 1,240 of 1441
- Jul 2011
- 71
February 14th, 2018 11:22 AM #1231how will i know if 2L-T?
i saw one that is not efi turbo.
ang nakasulat is d turbo ceramics.
tho, 2L sya. pero parang iba ang porma ng engine compare to my revo orig. how do i post picture ba?
- Apr 2008
- 6,237
February 14th, 2018 12:32 PM #1232AFAIK yan na nga ang 2L-T, and then pag 2L-TE "EFI diesel turbo". Pero makita mo rin naman na wala syang kasamang computer box kapag 2L-T lang. Same cam cover as the 2L, may turbo lang na dagdag.
Halata ko lang although pareho yung basic na tunog ng 2L sa 2L-T, ang laki ng hinina ng volume ng 2L-T pagkumpara sa 2L ng Revo na parang laging may matinding engine knock kahit maayos naman talaga ang makina.
Best if you bring a trusted mechanic who has experience with engine swaps to check out the engine before making any purchases para hindi sayang ang pera.
Sent from my SM-G900I using Tapatalk
- Aug 2012
- 2,767
February 14th, 2018 02:04 PM #1233
- Feb 2018
- 2
February 25th, 2018 02:22 PM #1234
- Aug 2012
- 2,767
February 26th, 2018 10:26 PM #1235
- Feb 2018
- 2
February 28th, 2018 02:07 PM #1236
- Nov 2014
- 9
March 6th, 2018 07:34 PM #1237Mga sir alam niyo po ba saan yun location ng flasher relay ng Revo SR. Thanks
- Mar 2018
- 1
March 15th, 2018 03:09 PM #1238
- Apr 2018
- 1
April 16th, 2018 02:11 PM #1239Good day mga ka TROC
I own a 99 Revo GL diesel binigay sa’kin ng father ko when they move to a different country. Napansin ko kasi medyo matigas yung gas pedal nya kaya hirap humatak, so I’ve search on google and youtube for some possible cause and DIY repair. Most ng nakita ko is about dirty throttle body and also suggestion to lube the throttle cable.
Naalala ko nung magpalit ako ng compressor nabanggit ko yun sa mekaniko and he did the same thing he lubed the throttle cable pero after almost a year eto bumalik ulit pero hindi kasing lala gaya ng dati. So ngayon nung bumalik ni-lube ko ulit yung cable and also check the air intake nakita ko may dalawang malaking punit yung intake hose(tinakpan ko muna ng duct tape for temp solution) I’m planning to buy a rtv sealant today to fix it kung wala akonh mahanap na replacement part.
Then tinignan ko din yung kabilang dulo(sorry hindi ako ganun karunong sa engine parts and terms hahaha) ang kapal nung dumi (boxed on 2nd pic) it’s all grimed up.
So long story short po, any suggestion about my concern, how to clean that part, what to use when cleaning it(materials and solvent cleaners), and do i have to take that metal part out when i clean it? Thank you po in advance.
- Sep 2010
- 2
May 24th, 2018 12:38 AM #1240Last edited by pope0717; May 24th, 2018 at 12:41 AM. Reason: email address
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
