Results 1,211 to 1,220 of 1441
- 52,727
October 20th, 2017 12:15 AM #1211
- Aug 2017
- 37
October 20th, 2017 08:20 AM #1212dr. d is right, you have other problem in your a/c system. in your story a rag was put inside the clutch fan, the intention of that mechanic was to make sure your fan is always engaged at the expense of efficiency, it means your fan spins the same with your engine rpm no matter what. Your A/C system should be pressure tested to find leaks...
Sent from my F5321 using Tsikot Forums mobile app
- Aug 2017
- 232
October 20th, 2017 10:17 AM #1213Had it fixed na. Culprit was the auxiliary fan and condenser (plus bracket). :/ No need to change clutch fan. Damage, with additional freon since it disappeared again, is 3500.
Sent from my EVA-L19 using Tsikot Forums mobile app
- Aug 2017
- 37
November 7th, 2017 03:28 PM #1214good day mga ka-TROC, ask ko lng po kung may nkapgpalit npo sa inyo ng radiator? how much po brand new?
- Nov 2017
- 12
December 2nd, 2017 11:56 AM #1215
- 52,727
December 2nd, 2017 09:02 PM #1216
- Jan 2017
- 29
January 5th, 2018 11:42 AM #1217Mga sir may differential gear oil ba ang 7K engine REVO-SR with matic tranny?
- Apr 2008
- 6,237
January 5th, 2018 12:08 PM #1218^Meron bro. Since rear wheel drive ang sasakyan natin, meron syang differential. Check your manual for the oil specifications.
Sent from my SM-G900I using Tapatalk
- Jan 2017
- 29
- Jul 2012
- 31
January 6th, 2018 08:56 PM #1220just sharing. i inquired with toyota bicutan re atf for our toyota revo glx 2000. they recommend the type 4. but as per owners manual, we should be using the dexron III. but according to them, they don't have that one anymore. so they're using the type 4. the attached photo was sent to us a day ago.
