Results 1,101 to 1,110 of 1441
- Aug 2016
- 7
January 19th, 2017 01:12 PM #1101
January 20th, 2017 05:11 AM #1102
Thank you sir. Did a quick research and mukang hindi na ganun ka available sa market yta si Dexron II and Dexron III nman is backward compatible. Any brand that you would recommend? BTW I'm using a manual transmission for my toyota revo. Mejo nagulat ako na same din pla ang fluid na ginagamit for both automatic transmissions and power steerings. Pra din pla syang brake/clutch fluid.
January 20th, 2017 05:13 AM #1103
- Aug 2016
- 7
January 20th, 2017 05:44 PM #1104
- 107
January 21st, 2017 10:40 AM #1105
- 107
January 21st, 2017 10:43 AM #1106
- Dec 2016
- 13
January 21st, 2017 09:01 PM #1107Hi sir! Same lang po tayo ng problema sa revo namin. Umaalog din ung manibela kapaga umabot ng 100kph. Rack end lang po yung pinalitan namin. Right and left side na rack end. Binili ko po ung rack end ng 1700, don't know if gaano sya tatagal. Last week lang po ako nagpalit sir. 300 lang din bayad ng service nya so a total of 2k po lahat. So far naman hindi na po umaalog simula nung napalitan sir.
Sent from my SM-J710GN using Tsikot Forums mobile app
- Feb 2017
- 2
February 21st, 2017 02:11 PM #1108god day po sir..
im a newbie with revo sr efi engine.. kaya madami po ako mga katungan sa mga kagaya nyo pong expext...=)
1. meron po ba kayo manual para sa efi 2001 gas engine revo
2. naexperience ko po kc sa revo ko na tumataas po ang temperature kapag nakarekta na or kapag mabilis na ang takbo like pag nasa expressway na, pero nababa nman po agad kapag binagalan nyo takbo or nagpahinga saglit... pero pag city driving or kahit traffic di nman po tumataas temp.
3. tapos parang napapansin ko po na parang sumisigaw ang makina or malakas ang tunog pag mabilis na ang andar. may batak naman po, pero parang malakas ang sigaw ng makina, ano po kaya un sir?
4. meron po ba kayo alam na pagawaan around calamba, los banos area?
regarding po sa question number 2 ko po, nakapagtry na po ako mag paoverhaul ng radiator dahil un po sabi mekaniko nung unang naexperience ko na tumaas temp na almost magoverheat na...
5.ang gamit ko po ay coolant sa radiator,pati po sa reserve... napansin ko po na lagi nlng nauubos at lagi po ako nagbabanto... normal po ba un?
sir malaking tulong o sakin ang inyong knowledge and experience tungkol d2...
salamat po sir...
- Apr 2008
- 6,237
February 21st, 2017 02:19 PM #1109^Nauubos ang tubig mo? Try checking if your water pump is functioning properly. Same goes for your aux fan. Hindi dapat nauubos ang tubig, nadudumi pero hindi nauubos. Check your hoses for tears or leaks. Check if your thermostat valve is functioning properly.
Kung dumating sa puntos na mabilis na sya uminit even after just travelling a few kilometers then you will have to check if you are in need of top overhaul.
Sent from my SM-G900I using Tapatalk
- Feb 2017
- 2
February 21st, 2017 02:33 PM #1110
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
