Results 1,091 to 1,100 of 1441
November 21st, 2016 10:50 AM #1091
tignan mo na lang sa data plate or sticker ng alternator..nakasulat naman don yung rated output.
40, 60 or 70 amps ang usual oem alternator
November 21st, 2016 11:31 AM #1092
Ok guys. Will check later tnx
Sent from my SM-J200GU using Tsikot Forums mobile app
- Mar 2003
- 124
December 5th, 2016 09:07 AM #1093maingay na release bearing ng GSX ko. mga magkano po kaya magagastos? ano papalitan?
Sent from my Redmi Note 3 using Tapatalk
- Dec 2016
- 13
December 8th, 2016 09:59 PM #1094Good evening po mga sir! I am looking for service manual ng Revo GLX 1.8 Gasolinr M/T. Baka po may copy po kayo. Thanks in advance po! Godbless!
Sent from my SM-J710GN using Tsikot Forums mobile app
December 13th, 2016 04:02 PM #1095
- Dec 2016
- 13
December 14th, 2016 07:51 PM #1096Okay sir, if ever po na magkaroon kayo, this is my email add po, daryljake_soriano*yahoo.com
Thank u sir!
- Jan 2017
- 29
January 9th, 2017 10:08 AM #1097Hi mga sir/mam, bago lang po dito sa forum, hingi lang ako ng opinion on this (post ko from other forum)
Napansin ko kasi kapag slow ang acceleration ko coming from full stop yung feeling ng gulong sa harap is parang dumadaan sa bumpy road, though di naman ganun kalakas pero kapag medyo mabilis ang accel wala naman. Also kapag na reach ng speedometer ang 100kph nag wiggle na yung manibela pero tolerable hindi malakas ramdam mo lang na may movement yung manibela.
May kailangan ba ko ipacheck?
check kung oblong ang gulong, wheel alignment and balance. steering components pa-check na rin.
Mga sir need your opinion on this:
Pinacheck ko yung sasakyan sa isang shop, inexplain ko sa kanila yung same sa post ko sa taas, upon checking nung mekaniko sabi nya maluwag daw bearing ng gulong sa right side, tinangal nila yung gulong then chineck yung bearing, sabi OK pa naman daw yung bearing, yung isang mekaniko naman ng check sa ilalaim ng sasakyan ang sabi nya may tama daw yung upper (bearing ba to o bushing/busing (ano ba tama). So yung isa binalik na yung gulong with proper greasing sa bearing, after nun ng check din sya sa ilalim dun nya tinuro sakin yung sinabi nung isang mekaniko at the same time sabi nya may alog na daw yung rack end sa right side ng sasakyan, tinanong ko kung kailangan na palitan, ang sabi nya itakbo ko daw muna at iobserve kung meron kabig sa kanan kasi daw baka maluwag lang yung bearing. Di na nila ginamitan ng computerized wheel alignment sabi kasi pantay naman daw ang upod ng gulong sa harap at diretcho naman ang manibela. Pinacheck ko din yung gulong sa likod to find out na may bukol na yung parehong gulong.
Regarding sa Upper at Rack end na sinabi nung mekaniko nag tanong ako ng qoutation binigay sa is umabot around 8.2k (4k labor & 4k part include ung 4 na upper at 2 rack end di sinabi kung branded/oem/surplus) nag advice din na pwede ako bumili ng parts at pakabit lang daw sa kanila. Ng tanong din ako na Ok lang ba na upper lang yung palitan, ang sabi nung mekaniko since may alog na daw yung rack end once daw na binaklas eh mahihirapan/baka di na daw maialign yung gulong (totoo ba yun?)
Eto ngayon ang concern ko (since medyo expensive at the same time base on findings sa back tires eh kailangan na din palitan):
1. If ever na pagawa ko yung upper and rack end reasonable price ba yung binigay nila? And kailangan ko na ba talaga mag palit ng rack end?
2. Kailangan ko ba magtry sa ibang shop for 2nd opinion?
BTW: yung auto is Revo SR, and dun sa mga check na ginawa nila ay wala silang siningil.
Salamat sa sasagot.. ^_^
January 19th, 2017 05:41 AM #1098
January 19th, 2017 05:48 AM #1099
Hello Sirs,
Just want to ask kung
anong brand and type of Power Steering Fluid ang ginagamit nyo with your Toyota Revos? Thank you in advance mga sirs!
- Aug 2013
- 475
January 19th, 2017 09:06 AM #1100
any feedback for America Lumina Nano Ceramic ? which better between Sunblock Ceramic vs Lumina...
