Results 61 to 70 of 308
January 31st, 2010 12:52 PM #61
The design and technology must be standard... BUT, the materials used are not exactly the same on every production plant... if the part is sourced from Canada, then the raw material used also comes there... kung sa Thailand gawa ang sasakyan, bakit pa kukuha sa Canada kung meron naman locally?? that will be additional production cost kung mag-i-import pa sila... materials have different properties even if they look the same due to the way they are manufactured (environment plays a major role)...
- Sep 2009
- 368
January 31st, 2010 01:47 PM #62I just asked a the Services Manager at Toyota Bicutan about the accelerator pedal in our 2009 Corolla Altis, he said that the accelerator pedal unit is DENSO not CTS, all the parts of Toyota models sold in the Philippines are sourced from Japan Toyota's home market.
January 31st, 2010 08:44 PM #63
February 1st, 2010 12:19 AM #64
FYI:
http://www.thetruthaboutcars.com/exc...o/#more-343512
This automotive web-blog has taken apart both the Denso and CTS units, as you can see, they're mechanically quite different.
Strangely, the CTS unit seems to be better... heavier duty... but the way the pivot is exposed on the side of the casing could possibly lead to moisture build-up that the supplier theorizes is causing the issue.
The Denso unit is completely different in the way it operates, and is nearly all plastic. They're still recalling it... it's unknown if it has its own separate issues.
What this means for us is that while there might be issues with the Denso unit, it's not the same as the CTS unit, and unless there are confirmed reports from Japan of issues with the Denso unit, people with ASEAN or Japan assembled Toyotas shouldn't be too unduly worried.
One worry of some industry observers is that the problem might not be with the pedal unit, but with the control software itself. And that Toyota's rushed "fix" of the problem might not fix it at all. But there is still no "smoking gun" pointing to numerous cases of "unintended acceleration" in local models... not yet.
- Jun 2008
- 1,740
February 1st, 2010 12:42 AM #65
- Oct 2009
- 20
February 1st, 2010 03:11 AM #66Kakatakot nga itong recall na ito, kasi baka nga sa design ang fault at di sa supplier. Ung sa China and Europe recall ba eh dun din ba nakuha sa supplier ng faulty part? Eh paano na lang tayo dito sa Pilipinas? Ung mga naka-encounter na ba dito sa atin sa Pilipinas ng sticky pedal ba eh nag-reklamo na sa Toyota? Sure meron na naka-encounter ng sticky pedal dito sa atin pero di na nag-reklamo dahil nga akalain na wala naman mangyayari kapag nag-reklamo pa sa Toyota. At sure na di lang sa mga mention na models naka experience ang mga Toyota vehicle owners dito sa atin.
Sana magkaroon ng pangil ang consumer protection agency ng bansa natin para naman manginig ang mga big companies sa mga complaints ng mga consumers at mapaganda ang mga products na nilalabas nila dito sa atin at mapaganda ang serbisyo nila. Kaya lang naman lumabas yang recall na yan eh dahil sa USA nangyari yang mga complaints na yan at maganda ang consumer protection agency ng USA.
Tanong, kung sa Pilipinas kaya ang case na yan, mapansin kaya yan?
- Mar 2009
- 184
February 1st, 2010 08:23 AM #67Its sad that statements like these reveal consumers' apathy on what government can do. I can't blame you though. Question is, have you tried approaching the company (then the government)? There are agencies in place where you can demand from companies should they not respond to your complaint i.e. DTI. If Pinoy consumers are serious about it, then they should file a formal complaint. Without a complaint, companies would not know about it. Moreso, government (so keep your letters, etc). Take the first step. Then see what happens. If its a legit complaint, then I believe that most companies who value quality will respond accordingly without pressure from the government. In this case, I believe that you're dealing with a company with a good service track record so I suggest that you take the first step and take it from there.
Hope this helps.
February 1st, 2010 08:58 AM #68
So, it is the mechanical linkage. My initial impression is that it is because of an "electronic translation", necessitating a new firmware....
9202:toothbrush:
- Jun 2008
- 1,740
February 1st, 2010 02:42 PM #70kung may recall ang toyota sa china at wala dito sa pilipinas ibig bang sabihin iba ang source ng parts sa china at dito sa atin. Para yatang hirap paniwalaan na ang china unit ay galing ng canada ang ginamit na CTS pedal.
Someone suggested that few years ago. Yung C5 daw opposite direction. ...
Traffic!
