Results 231 to 240 of 509
- Feb 2014
- 2,536
January 29th, 2022 04:01 PM #231well viscosity isn't the issue here the question is if an SN-RC mineral oil is good enough, if it's not then we'd all be seeing the warnings in all caps in all these user's manuals: DO NOT USE DINO JUICE
but we're not seeing those words. and let's not forget that a non-pao "fully synthetic" isn't actually FS. it's just highly tweaked dino juice that's allowed to be marketed as "fully synthetic"
so if a car says it needs at least api SL i'd be comfortable filling it up with any api SN oil i got lying around, knowing that it won't protect the engine as well as a PAO oil or high-end group3
January 29th, 2022 04:23 PM #232
- Jun 2011
- 1,080
January 29th, 2022 04:34 PM #233Kaya kung sapat naman ang power ng 1.2 for put puttering from A to B, mas madali at mura ang maintainance.
- Feb 2014
- 2,536
January 29th, 2022 04:42 PM #234
haha yeah. factory filled for life so if it craps out in 150k then that's the end of its life therefore "lifetime fluid" is accurate LOL. but of course not everyone reaches 150k so technically they don't need to change tranny fluid
the point is different people need different things. a person who tows trailers on the said tranny will definitely need to replace his lifetime fluid or else premature failure
so the same is true w/ engine oils. api SL is "good enough" for the raize as a minimum requirement. if you drive hard or plan to keep it for 20+ years then it's probably a good idea to use better oil
January 30th, 2022 08:37 AM #236
- 52,731
January 30th, 2022 09:39 AM #237
- Dec 2019
- 2,072
January 30th, 2022 10:41 AM #238Is manual tranny and diff fluids can last for a lifetime use?
Sent from my SM-N970F using Tsikot Forums mobile app
January 30th, 2022 11:02 AM #239
Probably not. Subaru recommends changing differential oils every 3 years and complying with it doesn't hurt... bought 3 liters of petron diff fluid, DIYed it, only cost me around 1.3k all in all. With how cheap it is, I don't know why one wouldn't change it...
Manual transmission fluid, I'd change it based on the recommended date printed on the service manual.
- Feb 2014
- 2,536
January 30th, 2022 12:33 PM #240
