Results 371 to 380 of 424
- May 2011
- 11
September 17th, 2011 07:19 PM #371Hi. Had it checked initially and the body ground was ok. Had the guages cleaned. The temperature sender replaced with a surplus part. The cylinder head gasket replaced (water overflows everytime i press the accelerator) and the radiator cleaned. Today is actually my 4th day at the mechanic bros and am really stressed over this. Please if someone has any idea. Thank you very much. Have a good one.
- Jan 2010
- 22
September 21st, 2011 01:25 PM #372
- Jan 2010
- 22
September 21st, 2011 01:26 PM #373
October 13th, 2011 07:58 AM #374
*datsun510
11 Blades ang fun ko at naka fix type na. at hindi ko pa rin npapare-checkup sa Ceejay's. Pero had may aircon thermostat switch replaced (ginawang automatic) sa Rey's Electrical.
October 14th, 2011 03:54 AM #375
Hi Sirs,
Just an update regarding my previous issue (high temp while aircon is on)
Radiator - Newly overhauled (with coolant and distilled water)
Aux Fan & Blower Fan - properly working and bagong linis (nacheck na sa CEEJAY's)
Radiator Cap - Newly Replaced
Aircon system - Newly Cleaned (by CEEJay's)
Newly Tune UP - Linis ang carb at palit ng sparkplugs, fuel filter and change oil.
A/C Thermostat Switch - Newly Replaced to Automatic (by REY's electrical marikina)
Cylinder Head Gasket - OK since ndi xa bumubulwak while reving-up. Gnun ba dapat while the aircon is on?
Water Pump - ano po ba indicator na sira na or ndi gumagana?
Radiator Fan - naka-fix type and 8 fins na
Im thinking if sa water pump, tubo, or sa Cylinder Head Gasket ang prob.. Need some of your inputs regarding this issue of mineTIA
- Feb 2012
- 19
March 3rd, 2012 09:10 PM #376Magandang Tsikot mga fellow Liteace Owners,
I own a LiteAce GXL Skyroof JDM, and its reconditioning is almost finish. But sa pag test drive ko di ako komportable sa transmission which is ang isa sa mga major problem namin before at probably ngayon. BALIKTAD PO ANG SHFTING NYA NOON 2 4 R SA TAAS TAPOS 1 3 - SA BABA (btw converted ang liteace ko from AT to MT) ngayon naayos nila (Kinonvert nila ang shifting lever cable) and nasa normal shifting na xya pero ANG TIGAS MAG SHIFT (and much worst di ako halos mka kambyo sa 2 at R talagang ipwersa mu para kumagat) sabi sa akin ni Mr. Mekaniko gayun daw talaka kapag surplus/converted.
Mga Liteace mga Toyota expert may paraan ba para maging lumambot ang transmission ko? tama ba ang sinasabi ni Mr. Mekaniko?
MAraming Salamat sa
March 4th, 2012 08:49 PM #378
mga sir ok lang po nba kung walang ganito ung makina ng lite ace namin
(ung na bilugan po)
March 5th, 2012 12:10 AM #379
paano po ba palakasin ilaw ng liteace?
mahina po kc ung stock na ilaw niya
yup... DNGA-B = Avanza, Veloz, (new) Vios and Yaris Cross TNGA-C = Corolla E210, Corolla Cross,...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
