Page 36 of 43 FirstFirst ... 26323334353637383940 ... LastLast
Results 351 to 360 of 424
    #351
    Quote Originally Posted by Paul_01 View Post
    not an expert bro.. based on experience lang 'to.. ahmm.. kahit ba i-floor mo na yung gas mahina pa din yung hatak?
    pwedeng palyado na din yung makina.. try mong pa-tune up.. for the parts that you'd mentioned.. i think he's reffering about your clutch parts.. baka manipis na yung parts mo jan..
    pwede ding throttle body.. try mo palinis..
    Uu diin na pedal ko wla pa rin, ayaw tlga bumigay. I patune up ko eto pg d umubra mga tips nu. Mgkano abutin ng tune kea sir, bka my idea ka. thnx
    #352
    Quote Originally Posted by macgyver1432000 View Post
    Robinhood,
    Para ma-check natin kung kelangan na talagang palitan yung clutch system mo, ganito gawin mo:
    1. depress clutch and brake pedals fully;
    2. shift mo kambyo to 2nd gear;
    3. using your right heel, depress slowly ang gas pedal, pero naka-diin ka pa rin sa brake pedal;
    4. slowly release mo yung clutch pedal.
    Kapag namatay ang makina mo, it means ok pa yung clutch disc mo, pero kung di namatay at nag-slip lang yung clutch, well, palitan mo na. Usually it'll cost you more or less 6K. Balitaan mo na lang ako...
    Sir mac good day, nagawa ko na un tip nu at nmatay ang makina. Big sbhin ok pa clutch ko, ipatune up ko n lng bka umaus ang takbo. Slamat uli s tip
    #353
    hi van lovers,
    i also had a 90 model liteace, nung una naranasan kong tumirik kc nagoverheat nung naka aircon ako sa trafik sa cubao, then pina ayos ko, at ang ginawa sa condernser ko since katabi ng radiator inilipat ng gumagawa ng aircon sa left portion sa baba, at pinadagdagan ko ng malakas na auxi fan with separate switch para pag pumalo ung gauge swicth on ko lang yung auxi fan nacocool down na ung temp. so far lamig naman ng aircon ko thankful lang ako kc ung gumawa sa aircon ko ay napakagaling at hindi pa nananaga ng presyo. regarding naman sa bouncy movement ng lite ace ok naman ung sakin cguro weak na yung shock o ung suspension bushing kaya bouncy na.
    sa experienced ko sa liteace basta lang may tamang mekaniko ka na nagseserbis sa mga parts like: cleaning of breakshoe and pads, cleaning or replacing your contact point and condenser, cleaning your carborador with carborator cleaner, cleaning of sparkplug, checking the fuses and ligth bulbs etc.. etc.. i think smooth sailing yung van nyo, tulad nung sakin, i recommend na kumuha kayo ng magaling na mekaniko at sya na ang mag maintain para alam nya yung in and out ng van. ofcourse supportahn ng konting budget, magastos talaga ang may second hand na sasakyan pero pag alaga mo naman kahit papano hindi ka ipapahiya ng sasakyan mo.
    syempre hindi naman perpekto na yung pag aalaga ko, di lang namin makitakita ung coz ng amoy usok na naaamoy sa loob, chinek na namin lahat. pero paminsan lang kapag mabilis ako, pero pag nasa 40-60 ung takbo ko Ala namang amoy usok, at may isa pa minsan amoy gas naman, tipid naman sa gas kc pinalitan ko ng jet. malakas padin yung hatak... baka may alam kayo na cause nung amoy usok at gas tru your experience with your aprubal may i solicit a recommendation and solution to this matter. thank you.
    AYZ,
    #354
    Quote Originally Posted by adc_cool73 View Post
    AYZ,
    Kung nangangamoy gasolina, I suggest ipacheck yung carburator at fuel lines. Kung saan dumadaan ang fuel mula tank hangang engine, may maliit na tagas siguro.
    Kung amoy exhaust naman, check nyo yung buong exhaust assembly mula headers hangang dulo ng tail pipe. Check nyo din yung underside ng sasakyan kung saan nakatapat yung exhaust piping, baka may butas na tumagas na sa body mismo ng sasakyan. Delikado sa pasahero yan, baka ma-carbon monoxide poisoning kayo.
    #355
    hi gusy.... may idea pa ba kayo kng ano pa ba problem ng liteace ko?
    nag palit na ako ng carb pati fuel filter pag start pa rin namamatay pag tumagal. tapos hirap na mag start ulit... pero after a day ma iistart mo ulit. pero namamatay ulit..
    #356
    Quote Originally Posted by quest_uy View Post
    Kelan ang last tune-up? Gano na katagal ang spark plugs at contact point? Pacheck mo ignition coil, high tension wires, pati yung loob ng distributor, baka naglalawa na sa langis.
    Jan 2011
    #357
    mga bossing,
    may problem po ba kung ang gas consumption ng liteace ko ('92 model) ay 8km/L sa city drive un and 10km/L long drive?
    from Fairview po ako, bka meron kayo trusted na mekaniko near our area for our liteace...
    maraming salamat sa inyo.
    May 2010
    #358
    Quote Originally Posted by dunhill21 View Post
    mga bossing,
    normal na yan. yung dati kong '94 gxl. ganyan din ang konsumo.
    #359
    gud am.. up natin.... ako problem ko ngayon sa liteace ko may bumubuga na parang foam na maitim sa aircon ko. minsan lang naman hindi parati.. do i need cleaning na?
    Mar 2011
    #360
    liteace peeps pwede bang palitan ng 5 lugs ang liteace natin parang sa mga 4wd na litea ace? and pwede din bang lagyan ito ng TEMS(toyota electronic modulated suspension)? magkano po kaya ang set nito front and back, pati saang surplus kaya meron? tia!
Toyota LiteAce Owners & Discussions Thread [Merged]
