Results 331 to 340 of 424
- May 2006
- 41
August 18th, 2010 11:13 PM #331
sir ano mga pinaayos mo? last time kasi pinagawa ko yung ilalim yung palit cross joint? yung tinanggal yung cross joint may malaking bakal na pang steering ata tapos yung isang side mataba sa kabila naman manipis. sabi raw yun yung cause ng tumutunog pag nag tuturn kahit onti lang. san po to sa antipolo? parang ang layo niyamay iba pang suggestions? :D
- May 2006
- 41
August 18th, 2010 11:14 PM #332
- Aug 2009
- 9
August 20th, 2010 09:25 AM #333
- Jan 2010
- 22
August 27th, 2010 11:48 AM #334sirs ,tanong ko lang po ,,pinalipat ko kasi yun a/c condenser na may 2 fans aux(yun isa pasadya ko inilagay) ng lite ace sa banda gitna ng van para di overheat..need ko bang lagyan ng fan yun space na dating kinalalagyan ng condenser?medyo nataas parin kasi yun temperature eh..4 rows na and newly overhauled yun radiator.
- May 2006
- 41
August 29th, 2010 11:26 AM #335
- Jan 2010
- 22
August 30th, 2010 01:44 PM #336*sir quest
walang nababawas sa oil and very clear pinkish pa rin kulay(caltex havoline semi) kahit 2k kms na natakbo nun van.no black/white /blue smoke coming out from the exhaust..will try to check the fan and waterpump baka nga dun ang diprensya..super ganda ang tunog ng engine,newly tune up/replaced yun contact point and condenser,spark plug,pasado naman sa emission test kaya lito nako kung ano yun cause ng high temp..
thanks sir sa advise,highly appreciated!
- Jan 2010
- 22
September 19th, 2010 11:28 AM #337sirs,,
napansin ko po ng pinalitan ng high speed/torque yun starter ng ace ,pag di umandar ng 3 days,no start na ito..click lang.push start kami pagkaganun.,pero may ilaw headlight at may busina naman kaya ibig sabihin may charge pa battery..need kaya nito ang change battery from 1sm to 2sm?yun alternator ay 90 amp na and newly tuned up ito las august bago nirehistro eh..ano kaya problem nito?
mas kelangan ba ng high speed starter ng power kesa dun sa dating low speed na starter?
- Aug 2009
- 9
September 20th, 2010 08:17 AM #338
- May 2006
- 41
September 20th, 2010 02:25 PM #339guys baka may idea pa kayo ano problem.
after ko kasi papalit yung carb ng liteace medyo mga 1-2 weeks siya hindi pinaandar tapos ngayon pag start ko namamatay na lang bigla.. kahit na todo tapak ng gas ko hindi nakakayanan namamatay ulit... hindi kumakagat yung pag tapak ng gas... nag iisip ako kung fuel filter yung problem or sabi raw baka fuel pump raw sila...may iba pa kayong naisip?
- Jan 2010
- 22
September 21st, 2010 11:00 AM #340*si quest
sir,,di po kaya sobra na liit yun jets na nakalagay??nag palit narin kasi ako ng carburator nasabi sakin ng gumawa na pagmasyado na sakal mamamatay naman yun makina.try nyo uli pa check ang mixture ng gas and air..
yup... DNGA-B = Avanza, Veloz, (new) Vios and Yaris Cross TNGA-C = Corolla E210, Corolla Cross,...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
