Results 251 to 260 of 424
- Jan 2010
- 2
February 1st, 2010 06:51 PM #251
- Jan 2010
- 22
February 3rd, 2010 06:54 PM #252ang price ng speedgear 1,050 brand new yun ,mahirap makahanap ng surplus.wala pa yun labor pag kabit.
To all:
di ba bawal sa carb type engine ang E10 gas?makakasira daw ng makina ang E10..meron na ba sainyo nagpa convert sa lpg?balak ko ksi pa convert to lpg ang lite ace ,kng nakakasira sa makina ang E10 gas..
- Apr 2008
- 33
February 7th, 2010 10:35 AM #253Good day tsikoteers!
Ask ko lang kung saan ang fuel drain plug ng fuel tank of LiteAce 91. May nakita akong plug but not sure kasi wala siya sa lowest level ng fuel tank. I was not aware that yong gasoline with bioethanol eh nakakasira pala ng carburator. Tnx.
- Jan 2010
- 22
February 7th, 2010 12:24 PM #254yes sir,may epekto sa carb type enginne ang ethanol gas..yun nga ngayon ang karamihan problem ng old car owners and non compatible cars kasi marami pa sa pinas ang mga 5yrs -10yrs old na cars na ginagamit pa..magkaka moist daw ang tank na mag cacauuse ng clogged fuel lines and it will also damage the rubber seals ,valve seals etc.
see toyota phil.info with regards to ethanol gas..and what models of cars are already compatible to it.
- Apr 2008
- 33
February 7th, 2010 06:46 PM #255sir mcrens86, do i need to drain the remaining fuel(with ethanol)? How about carburator baka masira din. Guys, anyone who knows where the fuel tank's drain plug? Or baka may access siya sa taas(at floor) para ma-siphoned ko na lang. Hindi ko muna siya gagamitin at baka lalong hirap sa pag-start. Pls help. I badly need it to be done hirap kasi magcommute.
- Jan 2010
- 22
February 9th, 2010 01:00 AM #256*boxanilin,
nun nag drain ako nun fuel ko sa tank,,yun mismo malaki na rubber hose na nakaka clamp dun sa tank hinugot at niluwagan yun belt nun tank para ma drain at tilt ng konti papunta dun hinugutan ng rubber hose.malaki yun hose na yun..di pwede 1 tao lng gagawa kasi may mag aalalay para di tuluyan mahulog ng buo yun tangke,..ang gamit ko ngayon E10 pa kasi halo ko sa blaze para taas pa octane level at bumaba ang ethanol mixture.
may nakapag sabi na ,may nag uup grade ng carburator ,,palit ata yun mga jets sa cooper at pati yun rubber hose nun fuel lines.di ko lng alam kung long term solution ito o bakasakali lang ng mga worried sa car nila na masira.
flex fuel hose yata tawag dun sa e10 compatible rubber hose..if you have other news like this pls.post it ,to make us all aware about the issue of E10 fuel.
- Jan 2010
- 22
February 10th, 2010 09:41 AM #257*boxanilin
kung hard starting yan lite ace mo,try mo pa check yun starter at battery baka di na ok yun starter mo..kasi ako nagpalit ako last october kasi inabot yata nun tubig baha yun starter ko ,3/4 nun gulong ko abot yun baha eh.
- May 2006
- 41
February 13th, 2010 01:29 PM #258
February 13th, 2010 02:24 PM #259
kapapacheck ko lang ng starter ko nung isang araw sa wizzard. they charge 550 sa labor and plus sa parts. wala naman pinalitan pyesa, nilinis lang but mas madali na un start nya compare sa dati...
we have a forum na for liteace owners... madami makakasagot sa tanong nyo.
liteaceclub.com
- Jan 2010
- 22
February 13th, 2010 09:11 PM #260*quest uy
palit starter recon only,,2,800 yun ,mahal kasi yun orig brand new..250 labor .
*vis
thanks for the info..will visit the club soon.
I don't have proof but it seems like the CRV shrank from the previous generation.
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
