Results 231 to 240 of 424
- Aug 2009
- 9
August 6th, 2009 11:26 AM #231good day mga sirs
kakabili ko lang po ng liteace 1991 model hard starting po sya ano po ba ang maiipayo nyo sa akin tungkol dito sa problema na ito.
thanks
August 9th, 2009 08:17 AM #232
Bro try pulling your choke cable because when your engine is cold you need more fuel to start properly then if push it back in if you sense that your engine is already up to operating temp. hope this help. and try to check your filter air&fuel if they are still in good condition. and check your ignition system coil/contactpoint/condenser/distributor cap,rotor/High tension wires. and check if timing is correct.
September 3rd, 2009 05:34 AM #233
try getting a tune up (and change oil)
one really good thing about the liteace is that its spare parts are unbelievably cheap, especially the shocks. bought the following last year from cruiser in sucat. all are genuine parts:
KYB Front Shock Absorbers 800.00 each (not a typo)
Toyota Contact Point 160.00
Toyota Condenser 100.00
Toyota O-Ring for Distributor 100.00
Toyota Air Filter 340.00
Toyota Fuel Filter 330.00
- Jun 2008
- 5
September 7th, 2009 10:27 PM #234mga sir, naka 97 lite ace po ako and carb engine, nakapag karga po ako ng unleaded na e10, ano po dapat ang palitan ko para di magloko ang engine? thanks!
- Jun 2009
- 2
September 8th, 2009 06:52 PM #235may liteace din ako and hindi compatible ang E-10 gasoline.
If ever pwede ba natin gimitin ang high octane fuels gaya ng Gold /w Techron(Caltex) para sa liteace?
September 12th, 2009 01:39 AM #236
- Sep 2009
- 3
September 13th, 2009 11:16 AM #237mga 'pre...
may on-going problem ako sa lite ace ko ngayon...
bigla na lang nasa maximum yung readout ng fuel gauge ko...
pati yung temp gauge ko, di pa ako nagsstart ng engine, mataas na rin kaagad yung reading.
if meron na sa inyong naka-experience ng ganito, kindly impart naman po if paano nyo tinroubleshoot...
saka nga pala, meron po ba sa inyo na may copy ng user's/owner's/repair manual ng lite ace?
thanks in advance!
September 16th, 2009 07:59 PM #238
- Sep 2009
- 3
September 22nd, 2009 12:38 AM #239
sir may previous experience na din ako sa hard starting ng liteace...
ipatingin mo sa mekaniko, if may compression loss na sa isa sa mga cylinders...
yung akin kasi dati ganyan, yung 4th cylinder (malapit sa transmission) may compression loss na due to No Good valve (di ko na matandaan if intake or exhaust hehe), pero nung napalitan yung valve na yun saka na-machining yung valve seat, naiistart na kaagad, kahit wala ng choke (kasi wala na talagang choke dahil kulang na choke mechanisms ng karburador ko hehehe)
sana makatulong
- Sep 2009
- 3
September 22nd, 2009 01:22 AM #240
Thank you very much sa advice mo sir...
Problem solved na, kaya lang it cost me to replace the entire instrument panel... :cry2:
Tama yung na-findout ko dun sa fuel gauge, may naputol na thin magnetic wire dun sa mismong loob ng gauge pero mahirap ng remedyuhan... :cry2:
Pagkalagay ng not-so-new na intrument panel, normalize kaagad readings as compared dito sa dati nya...
BTW, pareho lang pala ng meter yung FX saka liteace, pang-FX kasi yung nabili namin but basically the electronic board and the wiring sockets are the same... (yun nga lang, meron syang warning light for heater, eh petrol ang liteace ko hehe) nagawa naman namin ng paraan yung sa heater light tinanggal lang namin hehe
yup... DNGA-B = Avanza, Veloz, (new) Vios and Yaris Cross TNGA-C = Corolla E210, Corolla Cross,...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
