Page 23 of 43 FirstFirst ... 1319202122232425262733 ... LastLast
Results 221 to 230 of 424
    Jun 2009
    #221
    Quote Originally Posted by dixoy View Post
    ano kaya maaring problema ko kase po minsan nangangamoy gaas ung loob ng sasakyan ko. tska pansin ko ang init ng makina ko..mainit ung inuupuan ko eh.. pero d naman gaanong mataas ang reding sa temp gauge..
    hello
    i am a liteace owner din binili ko last april 2009 lng, i dnt know exactly the model/year basta im sure it's GXL. now i have the some problems noticed in my one month driving, first nangangamoy ng gas sa loob especially if open ang window, then maximum speed of only 80km/h and lastly lack of power. even after i change oil and oil filter, fuel filter, air cleaner etc ganun pa rin. then a local mechanic checked the carburetor and found out the secondary (i dont know what was it about) stock up daw. pero kahit after noon the same pa rin ang observation ko or kung meron man kunting pagbabago lng. not after mapansin nya na ang something like "advancer" daw na hose hindi nakakabit sa tamang lalagyan. kaya after noong macorrect na, changes were; 1. nawala ang pangangamoy ng gas sa loob. 2. maximum speed now is umaabot na ng 125km/h. aside from this two problems that are solved already, wala na akong reklamo sa liteace ko. aircon still excellent and fuel consumption estimate ko is 11-13km per li varying without and with aircon.
    i hope you can suggest your mechanic also to check yong "advancer" i really dont know what is it basta nawala ang problema ko the same as yours eh..
    Jun 2009
    #222
    Quote Originally Posted by zed2d View Post
    b4 gi convert nako to diesel ang akng engine mga 1:8 ang kaon kung ga aircon ug 1:10 kng wala sa sulod sa city if sa province padulong argao or badjian mga 1:12 way aircon using caltex techron silver. karn diesel na 1:13 ang sa city nga ga aircon ug 1:14.5 kunga wa aircon, and sa province 1:15-16 no aircon or occassionaly lang. using caltex power diesel. hope this helps. ug naay 2 ka instance nga nka 1:21 ko pero economy drive nagyud to padung toledo.
    nice presentation sir, maitanong ko sana regarding sa swaping mo ng engine ng liteace mo mga nasa magkano ang ginastos mo pati ang tire mo etc. nakita ko ang setup ng liteace sa link na binigay mo ang galing, gusto ko rin sanang gawin sa liteace ko. can you give me rough estimate ng budget. at isa pa meron bang pagawaan ng tulad nyan sa amin sa iloilo? any recomendation sir? thanx a lot and more power.
    #223
    Quote Originally Posted by afp1935 View Post
    If you wan't to swap a new engine like what I did try to source out an engine that its your need and your budget, because as of now the 3c-turbo diesel is kind of rare or if you could find one it might cost you a leg and a foot maybe 50k for the engine alone as of the price right now before it was 38K. And for the wheel and tire combo I traded in my old tire plus 20k the total money that I've spent for this project is approx. 200k all in all.
    But if you are going to do this for economy might as well maintain your engine with a good oil and maybe you would want to convert to auto lpg it's much cheaper around 20k-28k depends on who's doing the job.
    Now if you want to gain economy and a little bit more power from your engine the 5k you could use a bosch ignition coil + bosch super 4 spark plug , and use castrol magnatec 10w-40 semi-synthetic oil (1gallon use only 3.8L) change oil every 1ones year or 10K km,Bosch oil filter(part# 359) change your clutch assembly to exedy unity clutch assembly, and use castrol maual transmission oil API-GL4(2Liters) oil w/ pertua additive(1can approx. 400ml) for your transmission, and castrol gear oil API-GL5(1Liter) w/ pertua additive(1can approx. 400ml) for your diffs. and for your tires use 205/60R13 for your rear and inflate to 45psi and 185/70R13 for your front and inflate to 40psi. Use nankang Tire (nankang rx-615) at least this wont cost you more than 15K all in all. and use caltex techron silver as you fuel. And if you know of a good muffler shop there in your place you could opt to install a 4-2-1 header and a free flowing muffler. and lastly so that you won't encounter what other tsikoteers here have encounter with their unit as in overheating do not as DO NOT ever forget to add coolant to your water as in 50:50 mix I recomend petron coolant if available.
    Good luck bro.
    #224
    Sa akin is 30 lang tire pressure front and rare tires.
    Meron na pala tayong forum dedicated for liteace www.liteaceclub.com
    Jun 2009
    #225
    ok sir i do as you said when i go back home this month. i will update you the moment i finished already. anyway, i only want to do it first and foremost for economic purposes only. yong porma saka na lang muna hehehe... thanks very much sir... it helps me a lot.
    #226
    Mga sir,
    Good day po, tanong ko lang kung anong magandang replacement na bulbs sa headlights ng Lite Ace namin, 95.? Medyo may kalabuan na kasi yung orig na yellow halogen bulbs namin, mahirap bumiyahe sa gabi pag mahina ang headlights, ano po ba ang maisa-suggest ninyo na brand, model, wattage, etc. para sa tsikot ko. Thanks. Mine is a 1995 Toyota Lite Ace GXL, 5k...
    #227
    Bro jbiazon use wurth plasma white 100/90 400pesos each much brighter than the standard bulbs thats what I used before I change to Lihtninglabs HID 6000k worth 6k rin just so you'll know.
    #228
    meron po bang liteace na converted na sa fuel injected? thanks
    #229
    Quote Originally Posted by jbiazon View Post
    Mga sir,
    Philips X-tremePower H4 60/55W.
    Kung higher wattage ang bumbilyang gagamitin mo, kailangan mo rin palitan ang sockets at saka wiring para hindi matunaw.
    #230
    Quote Originally Posted by Cnetlasan View Post
    Bro if you want to use fuel injected you could try to install a 7k engine from a toyota revo or a 4a-ge engine.
Toyota LiteAce Owners & Discussions Thread [Merged]
