Page 10 of 53 FirstFirst ... 6789101112131420 ... LastLast
Results 91 to 100 of 525
    May 2005
    #91
    Sir, sinasabay na kasi ung tune-up sa oil change kaya palit na din ung fuel filter element. Ano na ba itsura ng fuel filter element pag 5k na? umiitim na rin ba? well, sabagay.... aside form the "dirty" fuel there is also an issue with d4-d before and changing the fuel filter element more often wouldn't hurt.
    This one's done only 7,500 kms
    A whole thread (w/ pics) on fuel filters at fortunerclub.ph
    Fuel filter
    What happens if you don't change fuel filter beyond what Toyota prescribes ?
    Post #39
    Hilux D4D Fuel filter - Page 2 - 4x4 Community Forum
    Dirty Fuel + No or infrequent change of fuel filter = diesel pump kaput
    May 2005
    #92
    This one has done only 7,500 kms.
    More here
    Fuel filter
    See post #39
    Dirty Diesel Fuel + Infrequent or no change of fuel filter = Vehicle Diesel Pump Kaput
    Just change the filter more frequently for peace mind and its not that expensive at 400-500 a pop.
    May 2005
    #93
    See post #39
    Oct 2011
    #94
    Thank you for the photo. maitim na din pala *7,500K.
    Aug 2005
    #95
    Quote Originally Posted by userfriendly View Post
    ^^ The d4d uses a timing belt. It actually has a tbelt light on the dashboard.
    Itong vvti? Chain?
    Aug 2012
    #96
    Hi Sirs,
    Magandang araw sainyo.
    Naka schedule din ako for 1k PMS bukas. D4-D manual po yung sasakyan ko. Ano po ba usually pinapalitan? oil filter lang ba at oil? at ano po ba recommended yung regular oil, semi synthetic or fully synthetic oil?
    Ito quotation sa akin. REG 2,500, SEMI 4,300 FULLY 5650. (OIL at oil filter included) pero sa mga nabasa ko parang mahal ito? please correct me if I'm wrong.
    By the way lahat po ba chenicheck sa 1st 1K check-up? gaya ng suspension? transmission, brakes, alignment? consider ko lang kasi nag long drive kasi ako 9 hrs trip at my mga rough road na dinaanan.
    thanks in advance sirs/ma'ams sa inyong mga sagot
    Jun 2012
    #97
    Quote Originally Posted by LuTh3r View Post
    Hi Sirs,
    Change oil talaga pag 1k para ma flush ung mga unwanted particles since bago gawa ung makina. Para saakin regular oil is best for brand new cars kasi mas mahihirapan ang makina para makatulong sa break in ng makina at ang maganda eh mura pa. Correct me if im wrong pero parang overprice ata ung mineral oil dapat below 2k lang yan.
    #98
    Itong vvti? Chain?
    Yup VVTi variant is timing chain, bro...
    16.9K:spam:
    #99
    Hi Sirs,
    For oil changes, up to 15TKm or so,- use only mineral (or regular) oil, bro. Helps the engine parts to 'sit properly'
    Then shift to semi-synthetic and then later fully synthetic oil.
    16.9K:spam:
    Aug 2005
    #100
    Almost due na for 10,000 km PMS. Malamang sa Monday ko i-check in. TAI.
Toyota Innova PMS (Periodic Maintenance Service) Thread
