Results 471 to 480 of 525
- Nov 2009
- 3,484
June 22nd, 2019 01:16 AM #471Also brake fluid being hygroscopic, water buildup in the reservoir is inevitable. Water being denser than oil will have to go down into the brake calipers/piston causing corrosion to the metal parts. That is why brake lining should be flushed periodically as per the PMS.
June 24th, 2019 09:52 AM #472
On power steering, can I do it diy? pag kabig ba left and right ok lang patay makina or dapat talaga patay makina? mejo alanganin ako mag bukas ng hose sa ilalim baka magka problema pa.
Yes you can. Kailangan nakabukas makina para mabilis ikabig pero kailangan off agad makina tuwing ikakabig kasi pressurized yung steering pump. Pwede ka naman gumamit nung sa turkey para hindi ka makalat
June 24th, 2019 10:53 AM #473
^ With the engine ON, it's going to be a 2-3 person job to do it properly so as not to damage the PS vane pump.
One guy on the driver's seat to turn the wheel
One or two guys to constantly pour new PSF in the reservoir (to prevent the vane pump from running dry) AND hold the container where the fluid is expelled. As the return line is free-flowing, the fluid tends to gush out violently when the engine is running and could spill all over if the hose is not held on to the container.
You can also do it with the engine OFF and it only takes one guy to do it
Get as much PSF out of the reservoir with a turkey baster and remove the return line and insert it in a container for old PSF.
Pour new PSF in the reservoir up to the brim (with the return hole temporarily plugged), get inside and rotate the steering wheel to one side. Pour in more PSF in the reservoir and turn the steering wheel in the opposite direction.
Repeat this process several times until you see clean fluid coming out the return line.
June 24th, 2019 11:08 AM #474
June 24th, 2019 11:21 AM #475
Power Steering Fluid Change QUICK and EASY - YouTube
- Nov 2009
- 3,484
June 24th, 2019 01:13 PM #476Instead of turkey baster, you could use a windshield washer pump or fluid pump available at online stores. They are less messy yet easy to operate. Pump could also be used to renew brake fluids in the reservoir, suck excess oil in the sump, and more..
- Jun 2009
- 131
June 24th, 2019 03:36 PM #477thanks sa mga inputs, mejo hinde ko pa ma figure out but watching the video naintindihan ko na sinabi ninyo. salamat ng marami sa inputs.
if i follow the video how many times you suggest to do the drain and fill method?
will twice be good enough? i'm thinking to drain then fill, run for a short ride, come back lunch muna then drain and fill again.
For the Power steering fluid, which Power Steering fluid is good? Toyota or pwede na sa Shell lang?
may video din ako napanood sa brake bleed kaso nakaka takot baka hinde ko mabalik mabuti yun drain needle sa caliper so better leave it to the expert nalang siguro.
June 24th, 2019 03:40 PM #478
Sa innova kasi na 1 bottle kaya mo gawin yan 2 times (yung 1 liter/1 quart). Yung una pang tanggal ng tira tira then yung 2nd pour yung gagamitin na.
Gumamit ako ng pureguard premium PSF. Yung clear.. para mas makita yung "latak". Yung usual kasi na available is yung color red fluid pero ok din naman.
- Jun 2009
- 131
June 25th, 2019 11:57 AM #479ok. 1 liter lang pala kasya na sa dalawang banlaw. haha.
Am i right that Yun Power steering fluid at ATF iisa? so pag nag pa dialysis ako ng tranny pa sobrahan ko nalang then yun tira yun ilalagay ko sa Power steering. TIV kasi yun bibilhin ko na ATF, from tranny dialysis, all the way from banlaw to final fill.
mga ilan liters po pala magagamit sa tranny dialysis?
on brake fluid, any review on Prestone brake fluid na DOT3?
June 25th, 2019 12:27 PM #480
Pwede ka gumamit ng ATF sa power steering pero i'd suggest na gumamit nalang ng totoong power steering fluid. Kung religious ka naman magpalit in the future ok lang siguro.
12 liters tapos another 3.3-3.8 liters ata para sa ilalagay na sa transmission. H
Ok naman ata
