Results 461 to 470 of 525
February 22nd, 2019 11:10 AM #461
Just had my pms 2 weeks ago. 100k odo reading replaced all fluids and timing belt. Innova d4-d.
February 22nd, 2019 11:20 AM #463
- 52,517
February 22nd, 2019 11:39 AM #464
- Sep 2014
- 2
June 5th, 2019 07:31 PM #465hi sir/s. i recently purchased a 2012 innova from a friend. do you have any recommended shop or innova expert mechanic in paranaque/las pinas area for the PMS. thank you in advance.
- Jun 2009
- 131
June 21st, 2019 04:26 PM #466Hello,
40k na yun innova namen na diesel, and i have questions sa mga tech experts.
Brake fluid - what the shop did was siphon all the brake fluid from the master, may mahabang hose pinasok sinipsip, tapos lagay ng brake fluid. mga 600ml naubos. hinde na daw kelangan i bleed kasi malinis naman daw yun brake fluid na inalis.
pwede na po ba yun without bleeding the lines?
Power steering fluid - do i need to replace it? what is the best way? pwede po ba siphon nalang from the reservoir tapos ikot ikot ng manibela para lumbas pa yun lumang fluid tapos siphon ulet tapos lagay na bagong fluid? hinde kaya magkaron ng hangin yun ganitong method? isip ko pwede din alisin lang laman sa reservoir tapos lagay lang bago.
Differential - pano po pinapalitan ng gear oil yan? dagdag lang po ba or i dont need to touch it just top up?
Transmission fluid - what is the best Dialysis or unplug lang ng bolt sa ilalim drain tapos refill ulet.
thanks in advance
- Apr 2010
- 739
June 21st, 2019 04:44 PM #467not an expert pero a few months ago nagpa 40K ago outside casa
brake - bleed for best results, pero ok na yan
ps - ganun ginawa ng mechanic ko. or possible din i disconnect low pressure line, mas messy lang
diff - may drain and fill bolts. pag umapaw na sa fill bolt, puno na.
transmission - drain and fill
June 21st, 2019 04:47 PM #468
Kailangan bleed parin.
Dukot ilalim. Pwede din siphon kung ayaw mo makalat. Kabig sa left and right para lumabas yung lumang fluid. Parang wala pa ako naririnig na nagkaroon ng hangin yung power steering.
Drain and refill. May drain nipple yan doon ka din mag-rerefill
Drain and refill kung every 2 or 3 years ka nagpapalit ng atf otherwise dialysis na.
June 21st, 2019 11:45 PM #469
taking the brake fluid from the reservoir only? wtf...
the brake fluid near the calipers take all the abuse aka (heat). you bleed them out and topoff the reservoir....
- Jun 2009
- 131
June 22nd, 2019 12:29 AM #470lol. yes pinadala ko lang kasi sa dad ko siya nag pa gawa. binilin ko sa kanya ano mga papagawa. habilin ko pa bleed, aba nung andun na siphon lang mahaba naman daw hose at malalim inabot, na buset nga ako mahal pa bayad 500, katwiran ng gumawa malinis pa naman daw yun fluid na inalis. sana ako nalang nag diy and just buy ourselves a pizza. hanap nalang siguro ako ng ibang shop na mag bleed, I worry kasi kahit first 40k yun, our car is an automatic so stress talaga preno.
On power steering, can I do it diy? pag kabig ba left and right ok lang patay makina or dapat talaga patay makina? mejo alanganin ako mag bukas ng hose sa ilalim baka magka problema pa.
on the tranny, no I don't want to change every 2 - 3 years, I think dialysis nalang ulet para good for another 40k na ulet yun.
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
