Page 40 of 53 FirstFirst ... 3036373839404142434450 ... LastLast
Results 391 to 400 of 525
    #391
    Much better have it scanned.
    Based sa experience ko sa gas na revo namin sparkplug problem pag may vibration.
    Check din yung wires
    Sent from my LG-H818 using Tapatalk
    Maraming salamat ulit bro, will do it by Monday.
    #392
    Here's the update after almost whole day in casa:
    - NO issue after scanning
    - general engine check up and suspension system inspection.
    - replaced spark plugs and engine tune-up (drive belts, ignition timing/dwell angle and fuel filter)
    Next to be carried out:
    - replacement of valve cover gasket
    - reseal timing chain cover
    - to reface rotor disc
    Sulit din yung visit ko sa casa kasi the engine response is just like her old self again.
    Jan 2012
    #393
    Sir, how much did the timing/dwell angle adjustment cost?
    tia
    #394
    Quote Originally Posted by 1natzt View Post
    tia
    IIRC, parang 642 pesos ang total labor nya kasama na yung ATF change out. Medyo mura kasi dahil manugang ng kumpare ko ang mismong supervisor na gumawa.
    Jan 2012
    #395
    I have the same problem sa innova gas, but the only thing na di ko nagawa is dwell adjustment. thanks sir.
    #396
    What is dwell adjustment?
    Thanks
    #397
    Thanks
    Inductive coil charging time para ma-maximize yung energy level nya.
    #398
    in english, please...
    Jan 2012
    #399
    Sir, ignition boost in simple terms.
    In my observation, for innova gas with more than 100k, it turns out that these may be some of the tuning tasks that are performed... timing and dwell adjustments, fuel and air filter replacements, and overall sensor cleanup(air and/or fuel).
    Please feel free to advise, if there are more affordable ways to tune the engine up, without the need to overhaul or replace expensive parts like pistons, fuel pumps.
    thanks
    #400
    This is my worry since the usual change oil / filters and other fluids as prescribed lang ginagawa ko sa aging innova namin. Baka meron pa dapat na hindi ko pala nagagawa.
Toyota Innova PMS (Periodic Maintenance Service) Thread
