Results 351 to 360 of 525
- Apr 2015
- 4
April 23rd, 2015 12:28 PM #351*dos2 *dr.d
Thanks for your inputs guys.
*StockeEngine
Thanks din sir and yes, kahit papano okay naman ung SA ko but I had nightmares talaga sa TPT branch!! Di ko man lang naramdaman ung excitement nung pag purchase ako nung first new car ko! Sa sobrang banas ko tinanggal ko agad ung sticker na ToyotaPasonTamo sa sasakyan sa harap nung agent!
Anyway, follow-up questions lang. I am not sure whether to use regular or fully synthetic oil. What's the difference po ba? TIA
- Jul 2012
- 15
April 24th, 2015 02:27 PM #352Kakatapos ko lang ng 15k PMS sa Toyota Balintawak. Nung una umabot ng 6,300 yung quotation sa akin. Pero napansin ko merong oil and fuel additives na pag tinotal is nasa 1,900 din. Pinatanggal ko na lang kaya I ended up paying 4,641. Mahal pa rin talaga sya for basic services such as change oil, oil filter, cleaning of brakes and basic inspections. I might choose to have my PMS outside next time.
April 24th, 2015 05:20 PM #353
*jay_delacruz
It's best to use synthetic oil sir. But any oil grade is acceptable as long as you change it regularly. I use mostly 10w/40 or 30 this grade is just right sa climate natin for daily driving. D sya malapot at di rin sobrang labnaw. Yun kasing 0w na grade parang tubig na sa labnaw. Mostly used in high performance engines. Yun 5w is good sa brand new cars dahil masisikip pa internals kaya medyo malabnaw para maka penetrate nang mabilis yun oil sa engine. Old engines naman 20w/40 grade medyo malapot na kasi may konting loss compression na.
- Apr 2015
- 4
April 29th, 2015 08:44 AM #354Thanks skyflakes! sa karagdagang kaalaman..
Nag pa quote din ako sa Toyota Shaw for 10k PMS, nabasa ko kasi sa ibang thread na they are the best when it comes to car services and eto ung breakdown ng job estimate nila.
10T KM PMS 1,700.00
(7) TDMO 1,414.00
1 OIL FILTER 425.00
1 GASKET 33.33
1 CAF 906.00
1 SET P.O.L. 3,300 .00
(P.GREASE,P.OIL, FLUSH,FUEL
TREATMENT,E/G DETAIL,BRAKE
CLEANER,MISC,SAND PAPER,
BATT. MIDTRIX/ENGINE TREATMENT)
IONIZER KIT 1600.00
Total 9,378.33
- 52,731
April 29th, 2015 09:29 AM #355
April 30th, 2015 10:55 PM #356
- Jul 2012
- 15
- Jan 2015
- 714
- 52,731
May 7th, 2015 02:29 PM #360kung change oil and oil filter lang, kahit sa neighborhood gas station. i use whatever is on the shelf.
yung air filter, kung hindi pa naman kuntaminado ng langis, ay pinabubugahan ko lang ng hangin.
bantayan lang nyo nang kaunti, at baka "may malimutan" ang mekaniko..
you should get by with 1500 kesos.
ngayon, for other services besides this, you will have to tell them what it is you want. they are not privy to the "casa recommendations".
Monk-owned R53
