Results 9,521 to 9,530 of 15378
- Feb 2006
- 108
November 13th, 2014 01:33 PM #9521kung sakali po ba direkta na lang ilalagay un toyota coolant sa reservoir or kelangan imix sa water
- Jun 2012
- 4,448
- Jun 2006
- 1,139
November 13th, 2014 07:11 PM #95231sm ata ang orig ng vvti, replaced it with a 2sm amaron. Malakas kasi parasitic drain ng 2 amp ko, lalo na at bihira ko pa gamitin ang innova.
November 13th, 2014 09:56 PM #9524
Of course bro... I was just clinging to the no basis "color match" ...
Read the instruction on the coolant carrier bro.. If it's a concentrate, you have to mix it typically with fifty percent water. You can also buy a ready mix which you can directly pour in your reservoir....
- Feb 2006
- 108
November 14th, 2014 12:34 PM #9525tnx po sir cvt yun kaya po prestone na color yellow yun lalagyan pede po ba sa innova
November 14th, 2014 01:43 PM #9526
Save yourself from stress.
Mura lang naman long life coolant bili ka na lang sa casa. Just pour it sa reservoir.
- Nov 2014
- 4
November 14th, 2014 09:28 PM #9527hi! ask ko lang po kung good deal na po ito.
innova e dsl at
discount 65k
keyless entry
back sensor
standard freebies.
sa monday ko pa kase makukuha. sayang wala pa lang grey metallic ung e varient. kulay chocolate tuloy kinuha namin
3years po sa banko. ako lang nag asikasoLast edited by sadsad; November 14th, 2014 at 09:29 PM. Reason: add details
November 14th, 2014 09:36 PM #9529
- Nov 2014
- 4
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
