Page 1506 of 1511 FirstFirst ... 140614561496150215031504150515061507150815091510 ... LastLast
Results 15,051 to 15,060 of 15102
    Jun 2005
    #15051
    Follow-up question.... are rainwater supposed to get inside the side doors and drips automatically? or there is already a problem with my gasket seals in my side doors?
    Design ng innova yan. May plugs sa ilalim ng doors. Problema lang kapag dumumi, nagbabara kay naiipon ang tubig.
    Inalis ko na lang lahat ng plugs. My older cars dont have it naman at di kinalawang
    Sent from my 2107113SG using Tsikot Forums mobile app
    #15052
    no car manufacturer wants water to get inside their cars' doors. but to make them truly waterproof, would be prohibitively expensive.
    so they do the next best thing: provide drainage.
    look at your car, sir, and see if the glass runners and the window rubber are warped.
    kung hindi naman... just enjoy your car, keep the drain holes open, and let the drain holes do their job.
    so why do car doors' drain holes get clogged?
    "dirt."
    Feb 2019
    #15053
    "dirt."
    Okay noted thanks dr. d
    Jan 2008
    #15054
    Yes..
    Meron lang plastic cover yan to protect yung sidings.. others use plastic with butyl waterproofing.. may iba naman na whole cover talaga..
    May drain holes yan usually 3.. corners and middle portion
    May 2017
    #15055
    Hello mga Bossings, malapit na ako magpalit ng timing belt for Innova 2015 Dsl. Nagtanong ako sa casa ang sabi ay 14.4k yung belt replacement kit and labor. Nagtingin din ako sa online sellers at may nagbebenta ng timing belt replacement kit ranging from 5-8k lang. Meron ba dito nakapagtry bumili sa online sellers na 5-8k lang kung legit na genuine parts or OEM or class A or just total waste of money? Salamats sa mga sasagot.
    Jun 2005
    #15056
    Quote Originally Posted by Mountain_Trail View Post
    Masyadong important ang timing belt.
    I would only buy it from the casa or an autosupply known to sell genuine toyota parts
    #15057
    i wouldn't try non-casa timing belt and labor.
    i have little ex-casa experience with timing belt kasi.
    Jan 2008
    #15058
    Meron naman shops that offer orig toyota parts like toyosco along edsa... piyeza din at ATCO meron orig toyota parts..
    Nung pina overhaul ko toyota 3zz engine, lahat orig parts kinuha ko sa toyosco
    #15059
    Yes..
    pulled the weatherstrip temporarily after i heard water splashing eventually removed the proper rubber plugs after i got home.
    https://youtube.com/shorts/QapHvcqQX5w
    Jul 2015
    #15060
    Hi guys, I have a 2005 Toyota Innova Diesel J variant. Lately nagpatint ako ng medium dark sa front pati sa side, and pinalitan ko din ilaw ko ng LED for both headlight and fog lamp (daylight yun beam). Medyo hindi ako sanay parang madilim kahit na both nakabukas ang headlight at LED. And sabi ng iba kapag umuulan daw or fog, mahihirapan akong magdrive kasi parehong puti ang ilaw ko.
    Ang question ko ay meron bang headlight na ang hi and low beam ay magkaibang color? Let's say low beam is white then hi beam is yellow. Can you guys recommend any LED or HID na medyo bright for dark tint pero hindi nakakasilaw sobra sa kasalubong? And if possible maginstall pa ako ng isang third light aside from headlight and fog lamp, possible kaya?
    Also, yun sa gulong ko, yun wheel center hub, yun isa nanakaw, san kaya ako makakabili ng ganon? I saw sa online parang may mga nagbebenta pero not sure if the size will fit.
    Thank you mga katsikot.
    God Bless.
Toyota Innova Owners & Discussions [continued 3]
