Results 14,881 to 14,890 of 14941
January 3rd, 2022 02:43 PM #14881
I don't know how "smart" is the integrated battery charger logic is in our cars, but 13.4V or whereabouts is pretty much bang-on for float-charging a full battery.
When the charging voltage is up to around 14+V, it just means that the battery is actively being charged.
I wouldn't worry about it.
- Apr 2010
- 694
January 5th, 2022 12:38 PM #14882called Yock's in Cubao, okay lang naman daw yung charging voltage. called Rey's in Marikina, mahina daw. parehas naman okay ito sa auto electrical sooooo....
need to have it tested sometime para matapos na, pero so far kahit iwanan ng several days malakas pa din mag start, so hindi nadidiskarga ang battery. or bili na lang kaya ako nung digital tester for our fleet hmmmn
- Jan 2008
- 4,362
January 5th, 2022 01:10 PM #14883per my auto experience, as long as hindi na discharge ang battery and the system voltage hovers 13.4 volts.. its good..
if voltage while idling is =<13V.. yan, may problem na ang system, either loose connection or the alternator is getting weak..
yung 14volts is usually the alternator's output if the battery is severely discharged where it barely started the car..
usually when you use accessories like radio for extended period with the engine off.
share ko lang din experience ko with alternators.. may diesel van kami dati na every time we use it, after 1 hour of driving eh na discharge yung battery.. kaya pag dating ng tatay ko sa office nila, he will charge it using a 220v charger.. then go home again with the battery discharged..
every time na dadalhin namin sa auto electrical shop, pag check nila, ok naman ang alternator charge.. 13.5V or higher pa nga.. medyo matagal tagal din na ganun yun.. pinalitan ko na fuse, wires, battery terminal.. ganun pa din..
until napag tripan ko buksan yung alternator.. upon closer inspection ko sa magnifying lens, ayun may mga crack pala yung solder ng diodes.. although may voltage, since loose yung diodes, nag intermittent on/off sya na hindi namin mahuli sa tester..
dinala ko dun sa isang electrical shop na may heavy duty soldering gun.. problem solved!
- 45,734
January 7th, 2022 01:14 PM #14884our old non-toyota van.
upon starting from cold, the alternator's output was low, but would normalize only after kadyoting the silinyador to higher rpm.
after that, ok na.
- May 2015
- 139
January 24th, 2022 02:49 AM #14885Good day mga ka-tsikot. Baka lang may interested. I'm selling my brand new/unused Westlake 205/65/15 RP36 with DOT 2021. I'm selling it for 8k for 4pcs. Purchased last December.
RFS: Ipapalit sana sa Innova namin, kaso nag offer ang tropa ng Rota SVN 16's sa presyong di ko matanggihan hehehe. Stock na lang sa bahay.
Get nyo na hehehehe. Pickup here * my place Paciano, Calamba, Laguna.
PM me na lang or you can reach me here 09357394943. Thanks!
Sent from my Redmi Note 8 Pro using Tsikot Forums mobile app
January 27th, 2022 05:44 PM #14886
- May 2015
- 139
January 27th, 2022 09:12 PM #14887Thank you for vouching the item Sir!
Aww. Iba rin kasi presyuhan per province, lalo na at Cebu pa kayo.
January 28th, 2022 07:19 PM #14888
February 2nd, 2022 11:22 AM #14889
Mga boss, anong Android Headunit and pwede nyo ma recommend sa all new innova? preferably Pioneer or kenwood?
Dami kasi model pwede pagpilian,... thanks...
February 2nd, 2022 02:34 PM #14890
Sa Mhonworks mo pa rin pina check sir?
2014 Mazda 3
