Results 14,281 to 14,290 of 15328
March 22nd, 2020 11:42 AM #14281
1. Spray with water
2. Spray with soap solution (1:5 Joy/Water)
3. Wipe-down using chamois cloth kung saan abot ng kamay
4. Rinse with water
5. Dry-wipe the surfaces with chamois cloth
6. Run the engine for a few minutes
Yung pressure washer namin may attachment for dispensing the soap solution.
March 22nd, 2020 12:11 PM #14282
- Jun 2005
- 3,774
March 22nd, 2020 12:28 PM #14283
March 22nd, 2020 12:50 PM #14284
- May 2015
- 146
March 22nd, 2020 12:56 PM #14285
March 22nd, 2020 01:01 PM #14286
The ECU is inside the cabin, behind the glove box.
The thing with the aluminum heat sink is the fuel injector driver.
Here's my post describing it, with picture.Last edited by oj88; March 22nd, 2020 at 01:04 PM.
- 52,731
March 22nd, 2020 01:32 PM #14287
- Jun 2005
- 3,774
March 22nd, 2020 01:55 PM #14288
March 22nd, 2020 02:02 PM #14289
Short of submerging everything in water, not really. So long as everything is fastened tight like electrical connectors, the air filter housing, and the fuse/relay cover, everything under the hood is reasonably impervious to spray water.
Just remember to keep the sprayer at least a foot away, give or take, just enough to dislodge dirt but not cause water to breach past the weather seals.
To add, set the sprayer stream to wide, not narrow. I know this is obvious but, just in case it’s your first time.Last edited by oj88; March 22nd, 2020 at 02:08 PM.
March 22nd, 2020 02:45 PM #14290
Monk-owned R53
