Results 14,881 to 14,890 of 15296
- Jan 2008
- 4,726
January 5th, 2022 01:10 PM #14881per my auto experience, as long as hindi na discharge ang battery and the system voltage hovers 13.4 volts.. its good..
if voltage while idling is =<13V.. yan, may problem na ang system, either loose connection or the alternator is getting weak..
yung 14volts is usually the alternator's output if the battery is severely discharged where it barely started the car..
usually when you use accessories like radio for extended period with the engine off.
share ko lang din experience ko with alternators.. may diesel van kami dati na every time we use it, after 1 hour of driving eh na discharge yung battery.. kaya pag dating ng tatay ko sa office nila, he will charge it using a 220v charger.. then go home again with the battery discharged..
every time na dadalhin namin sa auto electrical shop, pag check nila, ok naman ang alternator charge.. 13.5V or higher pa nga.. medyo matagal tagal din na ganun yun.. pinalitan ko na fuse, wires, battery terminal.. ganun pa din..
until napag tripan ko buksan yung alternator.. upon closer inspection ko sa magnifying lens, ayun may mga crack pala yung solder ng diodes.. although may voltage, since loose yung diodes, nag intermittent on/off sya na hindi namin mahuli sa tester..
dinala ko dun sa isang electrical shop na may heavy duty soldering gun.. problem solved!
- 52,700
January 7th, 2022 01:14 PM #14882our old non-toyota van.
upon starting from cold, the alternator's output was low, but would normalize only after kadyoting the silinyador to higher rpm.
after that, ok na.
- May 2015
- 146
January 24th, 2022 02:49 AM #14883Good day mga ka-tsikot. Baka lang may interested. I'm selling my brand new/unused Westlake 205/65/15 RP36 with DOT 2021. I'm selling it for 8k for 4pcs. Purchased last December.
RFS: Ipapalit sana sa Innova namin, kaso nag offer ang tropa ng Rota SVN 16's sa presyong di ko matanggihan hehehe. Stock na lang sa bahay.
Get nyo na hehehehe. Pickup here * my place Paciano, Calamba, Laguna.
PM me na lang or you can reach me here 09357394943. Thanks!
Sent from my Redmi Note 8 Pro using Tsikot Forums mobile app
January 27th, 2022 05:44 PM #14884
- May 2015
- 146
January 27th, 2022 09:12 PM #14885Thank you for vouching the item Sir!
Aww. Iba rin kasi presyuhan per province, lalo na at Cebu pa kayo.
January 28th, 2022 07:19 PM #14886
February 2nd, 2022 11:22 AM #14887
Mga boss, anong Android Headunit and pwede nyo ma recommend sa all new innova? preferably Pioneer or kenwood?
Dami kasi model pwede pagpilian,... thanks...
February 2nd, 2022 02:34 PM #14888
- Jan 2008
- 4,726
February 2nd, 2022 04:01 PM #14889
