Page 1489 of 1529 FirstFirst ... 1389143914791485148614871488148914901491149214931499 ... LastLast
Results 14,881 to 14,890 of 15287
    Jan 2008
    #14881
    per my auto experience, as long as hindi na discharge ang battery and the system voltage hovers 13.4 volts.. its good..
    if voltage while idling is =<13V.. yan, may problem na ang system, either loose connection or the alternator is getting weak..
    yung 14volts is usually the alternator's output if the battery is severely discharged where it barely started the car..
    usually when you use accessories like radio for extended period with the engine off.
    share ko lang din experience ko with alternators.. may diesel van kami dati na every time we use it, after 1 hour of driving eh na discharge yung battery.. kaya pag dating ng tatay ko sa office nila, he will charge it using a 220v charger.. then go home again with the battery discharged..
    every time na dadalhin namin sa auto electrical shop, pag check nila, ok naman ang alternator charge.. 13.5V or higher pa nga.. medyo matagal tagal din na ganun yun.. pinalitan ko na fuse, wires, battery terminal.. ganun pa din..
    until napag tripan ko buksan yung alternator.. upon closer inspection ko sa magnifying lens, ayun may mga crack pala yung solder ng diodes.. although may voltage, since loose yung diodes, nag intermittent on/off sya na hindi namin mahuli sa tester..
    dinala ko dun sa isang electrical shop na may heavy duty soldering gun.. problem solved!
    #14882
    our old non-toyota van.
    upon starting from cold, the alternator's output was low, but would normalize only after kadyoting the silinyador to higher rpm.
    after that, ok na.
    May 2015
    #14883
    Good day mga ka-tsikot. Baka lang may interested. I'm selling my brand new/unused Westlake 205/65/15 RP36 with DOT 2021. I'm selling it for 8k for 4pcs. Purchased last December.
    RFS: Ipapalit sana sa Innova namin, kaso nag offer ang tropa ng Rota SVN 16's sa presyong di ko matanggihan hehehe. Stock na lang sa bahay.
    Get nyo na hehehehe. Pickup here * my place Paciano, Calamba, Laguna.
    PM me na lang or you can reach me here 09357394943. Thanks!
    Sent from my Redmi Note 8 Pro using Tsikot Forums mobile app
    #14884
    Quote Originally Posted by johann123 View Post
    I think that's a very good price already even with it being R15.
    I just came from our local shop here in Cebu to replace 2 of my tires. Achilles 122 205/65R16 * 3.5k each.
    May 2015
    #14885
    Quote Originally Posted by blank check View Post
    Thank you for vouching the item Sir!
    Aww. Iba rin kasi presyuhan per province, lalo na at Cebu pa kayo.
    #14886
    Yup, medyo mahal talaga outside the metro. SRP nung innova nga at least 50k yong difference. The innova we have we actually took out from Toyota Bicutan
    Jun 2013
    #14887
    Mga boss, anong Android Headunit and pwede nyo ma recommend sa all new innova? preferably Pioneer or kenwood?
    Dami kasi model pwede pagpilian,... thanks...
    Jan 2009
    #14888
    Quote Originally Posted by Erick Chavez View Post
    Ang daming "it depends" dyan. Budget ang no. 1.
    Ano ba mga models na tinitignan mo na pasok sa budget? Dyan ka magsimula.
    Jan 2008
    #14889
    Yung pinaka mataas na model na.. may wireless carplay and android auto na
    #14890
    I'm using one that's outside your preference. I got one of those generic Chinese android units since September. No issues so far for what I need it for.
    Not promoting but I got the S7 model without the 360 camera.
Toyota Innova Owners &amp; Discussions [continued 3]
