Results 14,821 to 14,830 of 15321
- Nov 2011
- 473
October 27th, 2021 04:12 PM #14821its not me who needs to prove it, its their seat foam supplier who should have foam firmness tester that they should have on manufacturing the foam seats. if they dont have such, then they just manufacture without standards and should replace on/by demand/complaint...
dati nung si uratex pa ang supplier ng foam eh meron sila tester, even sa display showroom ng beds nila ngayon eh meron sila tester, di ko lang alam sino supplier ng foam seats ngayon, ayaw ko naman baklasin yung seats para lang malaman sino ang supplier/manufacturer...Last edited by jresperanza; October 27th, 2021 at 04:15 PM.
October 27th, 2021 04:17 PM #14822
Mas matigas ba or mas malambot ung upuan sa problem area comapred sa demo unit or may parang nakausli? If the later baka mas madaling i push for replacement pero kung ung former baka sabihin lang na mas gamit ung upuan ng demo unit at kelangan lang gamitin ung sa unit mo.
- Nov 2011
- 473
October 27th, 2021 04:18 PM #14823yes, checked that, seatmate is charging me a min of 9500 for all leather seats, too steep for a bnew car na mas comfy pa yung same variant na naka display sa casa
yes, neighborhood friendly spiderman siya
- Nov 2011
- 473
October 27th, 2021 04:19 PM #14824
- Nov 2011
- 473
October 27th, 2021 08:13 PM #14825yung sa unit namin ito nasa pula ang matigas kaya iniiwas ko pwet ko dito at dun ako sa green umuupo (likod ko naman ang sasakit kase di naka sandal ng ayos) o kaya naman nilalagyan ko ng twalya para kahit papano di ko siya maramdaman, may improvement kung may twalya pero nakaka inis kase nag iislide yung twalya kada galaw ko / upo ko tska brandnew ito july 2021 baket ko kailangan gawan agad ng paraan
yung upuna sa casa na naka display unit (same variant) eh manufactured Sept 8, 2021, mas malambot siya dun sa pula part, yung unit namin manufactured June 26, 2021. nung una kuha pa lang namin sa casa eh may naramdaman na ako, pero di pa agad ako nag reklamo kase akala ko naninibago o may mali lang ako sa adjustment ng silya, pero habang tumatagal eh mas lalo lumalala yung sakit...
November 1st, 2021 03:15 PM #14826
Looks like you need to check on your thermostat as dr. d mentioned. Might be stuck open. Easier to check on cooling systems with the pressure cap on the radiator itself. If that's the case for 1st gen innovas then you can check it yourself by opening the cap in the morning after starting the car. Coolant should not be flowing by when you look inside the radiator's cap hole.
2nd gens have the cap on the overflow so the same procedure above is not possible. At least from what I can see on mine. Or maybe there's a way that I don't know of.
- 52,729
November 1st, 2021 10:25 PM #14828
Wondering which configuration is better between using a pressure cap on the radiator (my gen 1 vios, and all previous 90's car we had) and those having their pressure caps on the expansion tanks (I guess it's safe to say for all Innovas, Hi-Lux and Fortuners).
Anyway, my innova gets to its operating temp (~90ish Celsius) in about 10 minutes I think. Will check tomorrow when I drive the in-laws to the airport
November 1st, 2021 11:14 PM #14829
On my Diesel 1st gen Innova, it takes forever to reach operating temp (temp needle midway through the gauge) when it's just idling. The warm-up is faster when you just drive it a few kilometers.
Still, my Civic warms up quicker, even when idling. In fact, when I switched to the Innova, I, too thought that the thermostat was faulty. That's until I tried my brother's Innova. So I'd say it's normal for this vehicle to take longer to fully warm-up.
If I were to wager a guess, it might be because of the hefty hunk of metal that is the engine block that Diesels have. It has a larger thermal mass compared to a gasoline engine so it can soak up more heat.Last edited by oj88; November 1st, 2021 at 11:16 PM.
- Apr 2010
- 739
November 4th, 2021 12:03 PM #14830kasya yung Baldwin B2 versus the BT223 na direct replacement for the Toyota oil filter. this is for the 2KD, not yet sure sa 1GD engine.
sinubukan ko ilagay sa Innova kasi marami akong inorder na B2 for the NP300, pero may minor leak kahit same thread naman
micron rating is better: B2 | BT223 and at 1.5x the length, mas maganda ang filtration.
Yes Yes squeaking sound is heard when shifting only
