Results 14,671 to 14,680 of 15321
May 3rd, 2021 06:48 PM #14671
ok, so after around 1,000KM of running the innova with the fan clutch always engaged, i couldn't bear the noise anymore. not only the noise but seems like the power/torque wasn't as good as before.
so i asked my mechanic cousin to help me remove the clutch so that i can drain the excess silicon fluid to get it down to the correct quantity. and now everything's good.
- 52,729
May 9th, 2021 08:18 AM #14672i have problem.
my 2005 innova E's dashboard lights have become very weak thru the years.
not the icons, which remain bright as new, but the lighting to the rest: the speedometer, rpm meter, temp gauge and fuel gauge, and lcd.
even my aircon dash lights and radio lights are weaker now.
no, my car did not come with light adjuster knob.
suggestions?Last edited by dr. d; May 9th, 2021 at 09:54 AM.
May 9th, 2021 11:25 AM #14673
Does that model have an always-on dashboard illumination (instrument cluster and center console for A/C, radio, etc.)? If yes, does it have auto-dim function when you turn on the parklights/headlights? Does it still work?
Otherwise, my money is on the combination of dim bulbs (probably due to age) and fine soot on the internal surfaces of your dash, affecting the light output.
- 52,729
May 9th, 2021 11:30 AM #14674nopo.
i have the on-or-off basic design illumination.
it goes on when i turn on the park lights, and goes off when i turn off the park lights.
i tried bringing down the instrument cluster from the front. it's so thin, i can't figure out how to open it and access the bulbs inside.
May 9th, 2021 11:47 AM #14675
Start with something simpler muna.... the A/C controls.
There are also videos on how to open up the instrument cluster. Search for Innova, Hilux Wigo, or other similar-gen Toyota vehicles of the era since they share pretty much the same cluster design.
- 52,729
May 9th, 2021 12:48 PM #14676thanks.
alas, the guy did not say the type nor where he got the replacement LED bulbs.
i remember repairing my aircon panel bulb. i ended up buying at greatly inflated price, from the casa, as i could not find it anywhere else.
if i opt to take the easy way,
does anyone know a shop where i can have this done?Last edited by dr. d; May 9th, 2021 at 01:02 PM.
- Jun 2011
- 1,080
May 9th, 2021 01:46 PM #14677
- 52,729
- Dec 2019
- 2,072
May 9th, 2021 10:16 PM #14679
May 10th, 2021 09:27 AM #14680
Electronic shops in banawe have this small T5 bulbs i did replaced mine last year as one of the aircon knob T5 got busted.
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
