Results 1,721 to 1,730 of 1815
April 3rd, 2011 08:38 PM #1721
Share ko lang.
This Saturday, I was at Toyota Cubao for my 5K PMS and for pull out of my headunit( for reimbursement). Nagpaquote ako sa service advisor for the PMS and I say to him that I'm using fully sythetic. The quotation was a whooping 5000+ plus. Nagulat ako. Kasi nagpa quote ako sa toyota north edsa 1700+. Sinabi ko sa SA na ibreakdown yung gagawin. Nung mabreakdown at na add up, 4000+ na lang. Then pinabawas ko yung fuel additives and engine wash, bumaba ng 2491. Wow hold up talaga. Wala na ko magawa. Hehehhehe di ko naman pwede alisin sand paper. Ang masama pa nirequire ako magdagdag ng langis dahil magpapalit daw ng filter, my God e halos tatlong kutsara lang ang nabawas. Ang nakakapagtaka, di ko maisip kung paano naging 4000+ yung 5000+ after i breakdown. Wala naman nabawas! My cut siguro ung SA sa bawat costumer nila. I've experience the service of North Edsa branch. Mas transparent sila. You guy who's unit comes from Cubao, be vigilant. Matindi talaga yung ginagawa nila. Tapos pinanonood ko sa bintana yung engine wash nila. Wala silang tinatakpan sa engine. Buga agad nang tubig. You can see that on the canteen's window. Ingat na lang sa mga unit na galing doon. Kung di lang sa head unit na isosoli ko, di na ko babalik dun.
April 3rd, 2011 09:07 PM #1722
sa 5K libre ang labor. so dapat oil filter at 1 liter lang ng oil ang bayaran mo.
April 3rd, 2011 10:27 PM #1723
Nag break cleaning, may synthetic grease,miscellaneous S&M-CAD,Filter, Oil, gasket, sandpaper and E/G & B/E system check-up. Standard daw yan for 5000kms. Ang di ko talaga macomprehend e nung pinabreakdown ko yung P5000+, naging P4000+ na lang. Wala pa naman akong ipinatatanggal. I did'nt bother to ask. Alam ko na, na meron something hidden on his list. Kung pumayag ako agad, ang saya siguro nung SA.
April 3rd, 2011 11:16 PM #1724
tanong ko lang sana about toyota engine oil...
sa manual ng innova natin
advisable ang 20w-50 15w-40 10w-30 and 5w-30 (gasoline engine)
but CASA are using the full synthetic 5w-40
if you have a choice? ano po ang pipiliin nyong Engine oil for your Innova? the 5w-40 or the 5w-30(in our manual)?
ito po ang engine oil ng shell which is same sa manual natin...
Shell Helix Ultra E has been formulated with special base oils to reduce friction, improving fuel consumption and exhaust emissions.
at meron din silang 5w-40 which is same sa CASA
Tanong ko lang sana kung may oil filter din ba ang shell at petron for our Innova?
TIA
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 3rd, 2011 11:29 PM #1725I will go for 5w30 or 10w30 over 5w40. It will give you slightly better FC and your engine will run a little smoother. This is provided your engine isin good condition and relatively low milage. If your engine have oil leaks, go with the thicker 5w40.
- Feb 2011
- 35
April 4th, 2011 10:03 AM #1726agent message: om monday po natin malaman kung may offer toyota phl ng innova G bronze inventory po nila today ( apirl 1 [ april fools?}) thanks po for waiting.
haay fingers crossed hoping for good news.
April 4th, 2011 03:25 PM #1727
ask lang mga bosing,yun bang mga technician/maintenance sa casa nag-iinstall kung sa banawe nabili yung parts or accessories na ipapakabit?thanks!
April 4th, 2011 03:35 PM #1728
I currently have a 2006 Innova J and just last week may bago na naman akong 2011 Innova J! Haay, Innova for life!
April 4th, 2011 04:01 PM #1729
April 4th, 2011 04:26 PM #1730
gas engine po yung sa akin. Wala po akong tiwala sa D4D!
for maintenance, the usual change oil and change spark plug lang...
pero sinalo ko ata lahat ng palpak ng innova like leaking shock absorber, leaking gas tank and fumes comming from outside. buti na lang lahat under warranty!
fuel consumption ko 7-7.8km/liter city driving
available naman kagad ang parts. order this morning then dating this afternoon.
not sure if there are model na walang ng choking.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
