Results 581 to 590 of 1815
January 22nd, 2011 01:52 PM #581
mga ka innova paalala lang lock nyo mga spare tire nyo prati ninakaw sa akin (dont know when!?) kahapon ko lang napansin just bought a special lock for fortunner and innova kanina
- Dec 2009
- 58
January 22nd, 2011 03:03 PM #582
- Jan 2010
- 304
January 22nd, 2011 10:36 PM #583
- Dec 2009
- 58
January 23rd, 2011 06:11 AM #584
January 23rd, 2011 10:52 AM #585
dapat gawin nila itong standard (spare tire lock) sa package/freebies ng Toyota.
nung brandnew pa innova namin 2 weeks pa lang nanakaw na yung spare tire di namin alam kung saan nanakaw. naibalik pa nga ng maayos yung harness ng magnanakaw
January 23rd, 2011 11:43 PM #586
Madali lang nakawin ang spare tire kaya dapat palagyan ng spare tire lock. Ako nagpalagay kaagad kasi tinimbrihan agad ako ng SA ko. Ang ginagawa ng mga magnanakaw, pinasisingaw daw ang hangin ng gulong hanggang totally mawalan na ng hangin ang gulong. Sa ganitong paraan, iimpis ang gulong kayat ung naka-cross na nasa dulo ng kadena, madali nilang mai-twist, ayon laglag na kaagad ang gulong. Ingat na lang sa mga wala pang spare tire lock
- Jan 2010
- 207
January 24th, 2011 08:46 AM #587
- Jan 2010
- 207
January 24th, 2011 10:33 AM #588
January 24th, 2011 10:44 AM #589
Just wanna share to all with AT innova.
AUTOMATIC TRANSMISSION FLUID LEVEL (from toyota corolla 2004 repair manual)
(a) Park the vehicle on a level surface.
(b) With the engine idling and the parking brake applied, shift the selector into all the positions from ”P”
to ”L”. Then shift to the ”P” position.
(c) Pull out the dipstick and wipe off the fluid with a clean shop rag. Re–insert the dipstick and check that
the fluid level is in the ”HOT” range.
(d) Perform this check with the fluid at the normal driving temperature:70 to 80°C (158 to 176°F).
HINT:
After extended driving under harsh conditions (high speeds, hot weather, heavy traffic or pulling a trailer),
let the engine cool down for approximately 30 minutes before checking the fluid level.
[SIZE=4]other sites naman[/SIZE]
For 35 years, have been playing cars with auto trans ( I love autos) including tricking up these autos and there is only one way to check ATF oil which has never ever failed ..... drive car for 15mins as this will ensure the auto trans gets hot reaching its own operating temp.
The engine operating temp does not mean the trans is also equally hot. Eg., you start the engine first thing in the morning and allow it to idle for 10 mins and engine would have reached operating temp from the temp meter indicator, but during this idling time, the trans is still in P or N and the ATF hasn't had a chance to get hot (just warm only) and to flow to all the nooks n crannies of the trans and also with no shifting during the idling time. All these will not give you accurate reading.
Hence the reason for actually driving the car before ATF level can be checked.
In short, drive car for at least 15 mins or more, then stop car, pull handbrake and put gear in P or N. Take out dipstick, wipe with lint-free cloth, insert the dipstick into tube wait for 3-5 secs, pull it out and check level. Top up to required level if necessary.
[SIZE=5]which is which ang tama...[/SIZE]
in my own experience pag sakto ang ATF mo. Medyo gaganda ang FC nyo.
i experienced sobra ang ATF, medyo pumangit ang FC ko. then nong pinabawasan ko sa casa... Sobra naman ang pag bawas ata kaya nagkaroon naman ng problema nagkaroon ng THUG sounds nong di ko nagamit for 24 hours pero smooth ang shifting nya no slipping so low gear compared sa sobrang ATF, pero FC ko +2k/liter sa kulang na ATF.
Pag check kasi ng CASA ng ATF, galing sa biyahe ang Innova then nag 3000 rpm pa sya for 5 mins then P to P. kaya kahit kulang ang ATF naging sobra pa ng konti. ( tama po ba ang pag check ng casa?) tinatanong ko sila about exact parang nag dadalawang isip pa ang mga ito.
ilang beses na ako pabalik balik (4x) di pa rin malinaw sa CASA trabaho nila about this ATF.
kaya i'm asking about this
pwede po natin ma picture what level ang ATF nyo sa
1. umaga without starting your engine.
2. idle for 15 mins then P to P without running your INNOVA.
3. then after sa biyahe what level is your ATF.
but no one answered it
Sana may makatulong sa akin sa may mga perfect AT innova.
Sorry po kung naging makulit na ako...
Anyone knows where to download the repair manual or service manual for our INNOVA sir/madam?
HELP pls
January 24th, 2011 11:02 AM #590
madam saan po ba ang dealer nyo?
if you want i can give you my S.A.'s contact number for you to discuss your problem.
bdw,
my dealer is TMBC.
sensya na po ha, hindi ko kayo matulungan sa problem nyo J Manual po kasi ang akin. hindi ko alam kung malaki pag kaka iba ng ATF level between Manual & Matic Transmission.
God Bless
-dongb
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
