Results 571 to 580 of 1815
January 20th, 2011 04:06 PM #571
With our partnership with tsikot shop we are offering a group buy for our performance products.
We have the following products to offer...........
OBD2 Scanner/Digital Gauge - this device can scan error code and reset the ECU to turn the check engine light off and also it is a digital gauge reading every thing that is happening in side out engine.
ECU/Commonrail Performance chip - a full tuned chip that we can set specific value on our commonrail depending on the throttle position in every rpm, this is a true perfromance chip.
Injectors chip - The first chip in the Philippines to be use for the injectors it have 16 setting that can accommodate every modification you will do in your engine.
A 7 days trial will be available for individual that is interested to test out chips.
As a reminder our chip is not plug and play we have to tap it to the MAP sensor wires and ECU wires. Base on our test and research a plug and play chip is not really that effective in giving you additional hp or torque. Testing our product and seing its performance will be the best way to check it out. You may ask how would i know i have use 7 commonrail chip, 4 injectors chip and 2 DMS.
For more technical information pls do PM us (Jedi) or shoot us an email at normandysamon*yahoo.com / Tsikot*gmail.com
January 20th, 2011 06:26 PM #572
January 21st, 2011 08:54 PM #573
i remember nung last PMS namin sa Toyota Balintawak EDSA ako nag-carwash bago namin ipasok sa casa nakalimutan ko sabihin na wag na icarwash ayun, after nun bagong carwash nga siningil pa ko ng 80 petot.
ang hirap sa pakiramdam pag ikaw nagcarwash ng auto mo sabay uulan ng ganito palagi na lang inuulan sasakyan pag nagccarwash ako. no-joke.
sorry medyo OT.
January 21st, 2011 11:26 PM #574
January 21st, 2011 11:31 PM #575
may tumutulong tubig ata yun sa ilalim malapit sa may lagayan ng spare tire.ano ba yun?normal lang ba yun.bago pa innova namin 1 month palang.
January 21st, 2011 11:54 PM #576
January 22nd, 2011 12:38 AM #577
January 22nd, 2011 06:20 AM #578
galing sa rear aircon yan tubig. same sa front passenger side meron din tubig na tumutulo dyan kapag naka-on ang aircon mo.
January 22nd, 2011 08:40 AM #579
Sa Toyota Dasmarinas (Cavite) libre naman ang engine detailing at ang car wash, kaya lang di ko na pinagagawa 'to kasi ako na ang naglilinis sa bahay. Lalo pang dumudumi ang engine bay ko, imagine papahiran nila tila ng armor oil para lang kumintab ang mga hose at lahat ng nasa may engine, ang hirap tanggalin, malagki pa. Kapag carwash naman, barabara din kung maglinis, ako may sistema sa paglilinis. Tapos ibibilad nila sa initan, ayun natutuyo lang sa init ng araw. Pati ung mga gulong pinapahiran din ng armol oil , dinidikitan lang ng alikabok. Better to wash our own car, at least feel na feel natin ung pagiging owner.
January 22nd, 2011 10:04 AM #580
Monk-owned R53
