Results 12,221 to 12,230 of 13229
- Jan 2010
- 207
- Oct 2005
- 15
BANNER BANNER BANNER
- Jun 2008
- 1,439
March 17th, 2010 09:11 AM #12223'05-'06 models are notorious for being prone to D4D problems. And the car's more than 3 years old, which is past the warranty period. I'd suggest going brand-new, since you'd only have to add a little more for the J D4D. The E D4D is a bit heftier on the pocket, though.
- Oct 2008
- 40
March 17th, 2010 10:57 AM #12224Gud day to all! Galing din ako sa Toyota Dagupan for my 10K pms and paid 3k+ pero diko pinapalitan spark plugs at iba pang naka list dun. Kailangan ba talaga palitan ung spark plug sa 10K pms niya kasi nabasa ko sa manual na in normal use sa 40K pa dapat so medyo mis leading sa ginagawa sa kasa. OK lang naman kung may budget kaso wala so sabi ko sa next pms nalang OK lang sabi ng SA and may big difference po ba mga sirs kung iridium gamitin na sabi nila pero mahal naman...
March 17th, 2010 11:16 AM #12225
Toyota Makati and Toyota Manila Bay both recommends spark plug replacement every 20K for copper type and 40K for Iridium type.
If you need to replace spark plug just use the stock copper type Denso K20HR-U11. This is already sufficient to last even more than 20K Kms, and they are cheap at more or less P90 each.
March 17th, 2010 07:05 PM #12226
March 17th, 2010 07:15 PM #12227
March 17th, 2010 07:25 PM #12228
Sa mga natuyong tubig sa glass and windshield, you can use "Water Marks Remover". Nakabili ako nyan para dun sa aking vintage car. Sa Tru Value dito sa Park Square sa Makati ako nakabili. Ok namang gamitin, tanggal ang mga natuyong tubig. Nakalagay dun sa box ang procedure ng paggamit.
March 17th, 2010 07:31 PM #12229
- Oct 2008
- 40
March 17th, 2010 08:07 PM #12230Thanks for the info sir! so sa 20K nalang ako magpapalit ng spark plug at ung stock nalang gagamiting ko kasi mahal din talaga yung iridium 600+ ata...sir tungkol naman sa engine oil kasi mineral lang gamit ko may big difference ba ang fully synthetic oil in terms of performance and FC at longer interval ba change oil nito kung sakali? ride is innova G manual vvti...
Suzuki JIMNY [merged threads]
