Results 321 to 330 of 559
July 30th, 2012 02:36 PM #321
July 30th, 2012 02:50 PM #322
Bro, In my case Air is comming IN the tank that is why I am alarmed. I think Only Petron Blaze is the only pure gasoline (not blended with ethanol) being sold here. Pero hindi ko pa siya nasubukan. since ni release ung innova namin petron extra unleaded lang pinapa karga ko. I try ko i check ung filler cap mamaya pag uwe ko. baka marumi din. so aling part ang culprit?
Filler cap?
Charcoal canister?
Fuel tank assembly?
As experienced lahat ng sasakyan sa family(both efi and caburated) lahat sila puro POSITIVE pressure or when you open the filler cap...air is comming out of the tank.
1992 Toyota Corolla 1.3(carb) - Mine
2001 Toyota Revo 2.0(efi) - My Uncle's
2003 Toyota Revo 1.8(efi) - My Father's
2010 Honda Civic 2.0(efi) - My Uncle's
Lahat sila POSITIVE pressure ang meron...bukod tangi ung innova namin ang pahigop pag binuksan filler cap.
July 30th, 2012 03:09 PM #323
Madali mo namang malaman kung air/(actually vapor) is coming out of the tank...
Amoy gasolina from a distance when you remove the fuel cap...
Ang sabi sa article,- the canister works when you turn off the engine...
The canister goes unused until the car is turned off again.
An evaporative control system was developed to eliminate this source of pollution. The function of the fuel evaporative control system is to trap and store evaporative emissions from the gas tank and carburetor. A charcoal canister is used to trap the fuel vapors. The fuel vapors adhere to the charcoal, until the engine is started, and engine vacuum can be used to draw the vapors into the engine, so that they can be burned along with the fuel/air mixture. This system requires the use of a sealed gas tank filler cap.
16.4K:bond:Last edited by CVT; July 30th, 2012 at 03:11 PM.
July 30th, 2012 03:21 PM #324
Thats a relief, thanks CVT. Saken papalabas yung hangin, parang nag exhale normal lang pala yun?
Even my gas tank warped last time i haven't experienced na papaloob yun pasok ng hangin.
Ako most of the time shell super unleaded pinapagas ko, next option is petron extra unleaded.
July 30th, 2012 03:24 PM #325
July 30th, 2012 03:34 PM #326
July 30th, 2012 06:55 PM #327
July 30th, 2012 06:58 PM #328
July 30th, 2012 07:59 PM #329
Sir mile, pwede po pa explain paano ang DIY ng charcoal canister. Di po ba delikado gawin to? baka magkalat tayo fuel?
pansin ko sa isang hose ng charcoal parang papunta man yun sa baba left wheel parte yung hose na walang clip. di kaya barado yun? breather ba yun ng charcoal canister?
- Jun 2012
- 44
July 30th, 2012 08:56 PM #330Wah..may issue na rin po kyo sa canister..ngayun lng po ako naka pag online..the new fuel filler cap is the same as the old..no changes as per your pictures posted even the part number is the same..ma'am wag mu na po kyo mag full tank as a precaution para d mabutas ang tanke..
Yes Yes squeaking sound is heard when shifting only
