Results 161 to 170 of 559
March 6th, 2012 11:45 AM #161
Bro ang tagal ko na sa tsikot forums kaso until now (nakakahiya man) i don't know how to attach a picture sa post.
by the way have you checked you gas tank assembly kung may dent na ba siya? nakalubog papaloob? yung dent nung sakin is medyo malaki na, after siya nung brace that supports the gas tank. Tapos dun sa edge siya nag leleak. After turning off the engine it will leak for a while, patak patak then it will stop na din. I'll try to check later kung may handwritten number yun gas tank ko, ano kaya yun? parang identification number?
By the way hindi ba advisable na magpa full tank? after ko kasi malaman na nagleleak yun gas tank ko iniwasan ko na muna magpakarga ng marami. siguro maximum ko na pinakarga is 10 liters.
March 6th, 2012 01:18 PM #162
March 6th, 2012 01:23 PM #163
It looks like that to me,- maybe they were monitoring some batches in the tank deliveries? Not sure...
1. Post the pics in one of the filesharing sites like photobucket.
2. Get the url (http:://www.photobucket.com/username/directory/filename.jpg for example)
3. Insert [img] before the url and [/img] after the url. This will signify that you are attaching an image to your post
4. That's it bro.,- you have posted a picture.
15.1K:bouncealt:
March 6th, 2012 11:21 PM #164
*cast_no_shadow
Try those gas stations near Banawe if they can fix your gas tank holes, usually they have contacts on suppliers and subcontractors for special jobs like fixing leaky gas tank, search also Bulaong transmission specialist in Banawe here in tsiko they have good reputation here in tsikot probably they can help you in your leaky gas tank problem. - Just sharing some ideas where to go for fixing. Good luck again in finding a good repair shop.
March 20th, 2012 06:07 PM #165
na resolve na ba yung issue regarding sa gas tank on the vvti na New models 2012 facelift
April 10th, 2012 12:19 PM #167
Finally got my gas tank repaired. I think its more practical than buying a new gas tank assembly. Sad to say i had my charcoal canister checked by a mechanic and he said kailangan na nga daw palitan. I tried looking sa banawe kaso ang hirap humanap and may mahanap ka man ka-presyo din ng presyo sa casa. As of now i don't shut my filler cap totally, parang nakalapat lang siya so the pressure from the gas tank can escape since ayaw na talaga mag function nung charcoal canister ko. Im thinking may masama bang effect if you leave your filler cap open?.
By the way, my cousin owns a 2005 model ayun nabutasan din siya ng gas tank last week. nagpunta siya ng casa to have his gas tank assembky changed pinalitan naman. I asked if the service advisor advise na palitan yung charcoal canister niya kaso hindi naman pinalitan. Im thinking bakit kaya ganun ang toyota? hindi ba nila alam na yun ang deffect ng design ng inniva kaya nabubutasan ng tank?.
April 10th, 2012 12:22 PM #168
* mile2
sir nagpalit ka na din ng charcoal canister? ang haba na ng thread kaya i cant read back sorry.
sa casa ka ba bumili or sa labas? sa banawe kasi ka-presyo ng casa ang alok sakin.
thanks!
April 11th, 2012 10:43 PM #169
*cast_no_shadow
My first gas tank replacement
Only lasted less than a year, it was replaced by my insurance company plus my insurance participation fee. TMBC did not replace the charcoal canister and filler cap then. All the while I thought my first gas tank got hit by hard object so I had my welder build me a gas tank skid plate that will cover the whole gas tank floor but I was wrong it was really a factory defect either on the Charcoal canister or the Filler cap. My replacement gas tank again leaked on the same spot even with skid plate protection.
TMBC workaround while I await approval of my petition for full warranty on the gas tank warping defect was they took apart the innards of the Filler Cap and removed the tiny plastic mesh filter inside the Filler Cap to relieve negative pressure build up.
2nd Gas Tank replacement
Yes, nagpalit ako ng Gas Tank Assembly, Charcoal Canister and Filler Cap all replaced by casa at no cost because I formally write a letter to TMBC President that this is a factory defect citing with pictures of my skid plate protector. This was my second gas tank replacement and the warping gas tank floor problem was solved.
I would highly suggest to replace the Charcoal Canister to avoid recurring warping gas tank problem. Try to call Gant Auto Supply if they have this part. Use the search function of tsikot for Gant's phone number.
April 12th, 2012 11:10 AM #170
Thanks sir mile2!
actually papalitan ko talaga yun charcoal canister, kung wala mahanap no choice sa casa na ako bibili. Im thinking forever na kaya na may deffect yun charcoal canister nila? lets say gaya mo you bought a new one gaano kaya ulit ang itatagal nun bago siya masira. Gladly naparepair ko yung gas tank nakatipid din ako ng 16k.
salamat ulit sa information.
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
