Results 21 to 28 of 28
- Nov 2006
- 8
September 18th, 2012 09:12 PM #21mga sir update ko lng, tried to make the tire pressure to 35psi pero ganun pa rin.
konting history lng po, pnagawa ko sa toyota dati kasi me narattle sa unahan, ginawa nila inangat nila yung fender kasi daw natama sa air cleaner, tapos ilang days tsaka ko lang napansin ang laki ng angat from hood to fender so binalik ko ulit sa toyota para gawan nila ng paraan what i've suggested is lagyan ng foam between the fender and dun sa me air cleaner(pero hnd ko pa nacheck kung yun nga gnawa nila) tapos pagcheck ko naibalik na nga yung angat nya between the fender and the hood kaya lng ayun nga parang lumkas yung vibrate sounds nya at parang bass sound.
tapos ang ginawa ko kanina inangat ko ulit yung fender palayo sa hood, ayun mejo nalessen yung bass sounds at vibrate, do you think dun na nga yun? and anyone else experienced rattling sound sa front right side ng toyota innova?
should i try to remove the fender or balik na naman ako sa toyota? kasi 2 hours byahe papunta dun toyota san pablo nga po pala e taga lucena city pa ako sa quezon
- 52,512
September 19th, 2012 12:38 AM #23tama kaya ang kabit ng air filter element? baka baligtad.. o wrong model.. baka hindi naka-clip o nawawala ang clip ng housing cover..
at tingnan mo rin yung mounting bolts ng air cleaner housing. baka walang twerka o maluwag.. tinatanggal kasi yan pag-service ng headlamp bulb, e..
my innova is reasonably quiet inside..
and i can not imagine your "aangatin ang fender".. mahirap gawin yan, even to an experienced mechanic. perhaps you are refering to some other part..?
tekateka.... baka yung rubber hood stops on either side of the hood..? they're flush to the metal in my mpv.
the only fender i know that's easy to lift, is the one that ramon jacinto ... heh heh.Last edited by dr. d; September 19th, 2012 at 12:43 AM.
September 19th, 2012 09:18 AM #24
WTF have they been doing with your Innova? Are all your panels aligned? Naaksidente ba yan before? What caused the air cleaner to hit the fender since we also had several Innovas and it's quite properly mounted unless something happened to the car before. I also used to get a low vibration sound when i broke one of the mounts on my Frontier's air cleaner.
- 52,512
September 19th, 2012 07:04 PM #25i looked at my innova's engine bay.. hindi ko ma-imagine...
curioser and curioser..
- 52,512
- Jul 2011
- 584
September 21st, 2012 01:43 PM #28walang bang update?
san kaya yung vibration na yan at nag-resonate sa low rpm?
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
