Results 1,961 to 1,970 of 2000
- Oct 2018
- 1
- Nov 2017
- 8
October 29th, 2018 01:00 PM #1962UP ko sir..
Paano po ba makakuha ng discount kapag ipapabank financing?
Nagtry na ako magtanong sa agent kapag in-house financing magbibigay sila ng discount na Php180k pero kapag bank financing nasa Php45k lang.
Nabasa ko kasi na dito na pwedeng magawan ng paraan na yung 180k ay magiging discount either inhouse or bank financing.
Salamat
November 4th, 2018 04:12 PM #1963
Mga boss ask ko lang po if ano itong 2 tubes na nasa ilalim ng engine ng Grandia GL? normal po ba ito? Sabi po sakin engine breather daw po. Ayaw lang mgsend dito mga boss nung picture
- Jul 2013
- 4
- Feb 2010
- 227
October 15th, 2019 10:35 AM #1965
- 52,729
October 16th, 2019 12:24 AM #1966
- Oct 2018
- 46
December 4th, 2019 04:10 AM #1967Can anyone actually confirm if the 2019 Grandia Tourer is either considered Class 1 or Class 2 in our expressways?
Technically it should still be Class 1 since the height limit to be considered such is to be 7.5ft (2286mm) and below, and the Tourer's height is at 2280mm. It's just that it's straddling so close to the limit that it can be controversial.
Perhaps those who own a Grandia Tourer can pitch in their experience.
- Apr 2012
- 3,469
May 15th, 2020 08:49 PM #1968Kanina while driving sa c5 biglang nawalan ng hatak Hiace ko.
Hanggang ayaw na umandar, no choice but to tow it para makauwi.
The problem is na sshift ko kambyo, pero pag inangat ko clutch pedal hindi naandar. Ni walang reaction yung engine. What could be the problem?
2015 model
Sent from my SM-A507FN using Tapatalk
- Jan 2008
- 4,726
May 15th, 2020 09:15 PM #1969
- 52,729
May 16th, 2020 10:39 PM #1970i don't hi-ace, but
if "ni walang reaction yung engine", you mean, it does not rev even if you step on the silinyador, something is wrong with either your silinyador or with your fuel enrichment system. if the connections are mechanical, the problem should be easy to fix. it might be something as simple as disconnected cable or cut cable.
but if the engine revs on command naman, but the vehicle does not accelerate, my guess is, the engine's crankshaft does not gets its power thru to the driveshaft. the only item i can think of that is between the two, is the transmission box.
a third possibility, although medyo no,
your fuel filter is clogged. not enough fuel can pass thru to allow your engine to rev.
The misspellings on that page are so funny! "Nono-ceramic" "In-Fared multi layer" :twak2: :grin:
