Results 31 to 40 of 682
January 27th, 2005 04:56 PM #31Originally Posted by jackaroo
sana engine ng hi-lux, 7 seater at 4wd!!!
wag naman sana over 1.3M...
January 29th, 2005 11:24 AM #32
hindi na ba ibabalik ang sequioa? bigla ko kasi naalala yun with this car... haaay... masgusto ko yun sa prado eh... parang in between prado and landcruiser... macho pero refined...
January 30th, 2005 07:21 AM #34
Does anybody have any link for complete SPECS? I have been searching pero mahirap yata makita.
January 31st, 2005 12:23 PM #35
also tried looking for it... unfortunately there is still none in the internet.
though you can bet on it that at least one variant will have the 3.0L d4d engine.
January 31st, 2005 02:02 PM #36
[SIZE=3]Toyota Fortuner SUV 5d 3.0 16v TDI 4WD aut.[/SIZE]
Number of seats--7
Engine
Engine code--1KD-FTV
Engine type-- Diesel, Front transversal
Number of cylinders-- 4, In-line
Engine capacity-- 2982 cm3
Number of valves-- 16 DOHC
Fuel-- Diesel, Common Rail
Supercharging-- Turbo + Intercooler
Bore-- 96.0 mm
Stroke-- 103.0 mm
Compression ratio-- 17.9
Max Power-- 120 kW (DIN) 3400 rpm
Max torque-- 343 Nm (rpm) 1400-3200 rpm
Transmission & Drive
Drive-- all-wheel drive
GearBox-- 4 Auto
Steering type-- Hydraulic power
Brakes & Tires
Wheels-- 7JJx16
Front tires-- 265/70 R16
Rear tires-- 265/70 R16
Front brakes-- Ventillated disc
Rear brakes-- Disc
Suspensions
Front Suspension-- Coil spring, Double wishbone
Rear Suspension-- Coil spring, Multi-link
Dimensions
Wheelbase-- 2750 mm
Length-- 4695 mm
Width-- 1840 mm
Height-- 1795 mm
Track (front)-- 1540 mm
Track (rear)-- 1540 mm
Curb weight-- 1925 kg
Consumption
SOURCE:Click HERE
Click on the Model Version, then a pop-up would give the specification
ADDITIONAL PICS:
January 31st, 2005 02:12 PM #37
From the looks of it, Toyota Fortuner is actually wider and longer than a Mitsubishi Fieldmaster. I really doubt it if this will be on the P1.3-1.5M range. But I am hoping though na within this range lang. Baka depende rin sa model version. But we'll see kasi ang specs are more likely to compete with the Pajero Fieldmaster which costs around P1.8M na ngayon.
Tsikot Member Rank 5
- 3,144
January 31st, 2005 02:18 PM #39
too pricey IMO. if Kia can offer the Sorento at such reasonable prices, why can't they?
January 31st, 2005 02:20 PM #40
Correction pala: Longer ang Pajero Fieldmaster by 40mm or approximately 1.5 inches..But still close..
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
