Results 41 to 50 of 50
- Jan 2010
- 5
January 30th, 2010 12:24 PM #41by the way fellow estima owners.
i have a incoming project,
possible po ba to change the drum brakes to rear disc brakes from aeras series? bolt on lang po ba ito mga sirs? how about the brake cable?
salamat po.
January 30th, 2010 11:57 PM #42
Sa tingin ko ay ok pero need to double check the whole rear drum assy and yung rear disk assembly mounting. Mine is factory installed rear disc brake (Aeras model). Yung handbrake nya ay connected din sa may center na parang drum brake din ang style. Di ko pa sya na baklas. Better to bring your Esti and remove the rear wheel tire and put side by side yung rear disk assy ng aeras for confirmation.
goodluck!
- Jan 2010
- 5
January 31st, 2010 10:08 AM #43
- Jan 2010
- 5
January 31st, 2010 11:06 AM #44good day sirs, question lang po. pwede po bang ireplace ng HKS or KNN na aftermarket air filter assembly yung stock airbox filter ng esti? im planning to replace it soon for my upcoming project..
kindly enlighten me on this mga sirs if pwede, pros and cons..
thanks
- Jan 2010
- 5
- Mar 2010
- 1
June 6th, 2010 10:51 PM #46Dream Works, pwede bang malaman kung saan ka nagpapalit ng coupler for propeller. ganyan din ang sakit ng estima emina ko.
thanks,
- Jun 2009
- 6
- May 2015
- 1
May 29th, 2015 09:50 PM #49Share lang! 😊🔰🚘
My ride is an automatic transmission toyota emina with 2TZ-FE engine. Liquid cooled and 2WD.
- 6
October 30th, 2015 11:44 AM #50Can anyone help me where I can buy a Drive Shaft Coupling for my Toyota Estima 3C engine near Cavite or Manila area. I got too much vibration specially when running with AC.
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
