Results 161 to 170 of 2023
November 12th, 2005 12:01 AM #161
Originally Posted by larshell
November 12th, 2005 04:15 AM #162
Haay nako buti na lang nag kulang ang pang down namin sa INNOVa J diesel... So adventure GLS Sport tuloy nakuha namin.... 1 click start!!! Mejo right decision pa rin kahit papano!
November 12th, 2005 06:10 PM #164
*likot yup somehow you did a right decision but sana you wait nalang 2006 Adventure.
*Innova_Boy, I did like D4d but wd my experince, i dont like D4d anymoreLast edited by larshell; November 12th, 2005 at 06:12 PM.
November 12th, 2005 09:25 PM #165
It would be interesting to know if the other countries where D4D owners are having problems have more stringent standards for diesel fuel than the Philippines. If these countries have cleaner diesel and the D4D engines still act up in spite of it, then that would really be a problem for Toyota.
November 13th, 2005 10:26 AM #166
Originally Posted by mikey177
"""Originally Posted by larshell
There's a problem din pala wd D4d abroad, Rav4 and AVensis. Nag google ako like mazdamazda said."""
I myself have been to indonesia and all I can see are Innova with VVTi engine only.
I was told that it's Innova country kasi sobrang dami ang Innova sa indonesia. Maski na yong lumang model, tawag sa atin Revo at sa kanila tawag nila Kijang, sobrang dami pa rin sa indonesia. I suspect baka may alam itong mga toyota indonesia tungkol sa D4D engine kaya di nila pinasok sa indonesia samantalang sila yata ang pinakamura as far as price of diesel sa whole asia. Ang sabi sa isang magazine nila, process of testing pa rin daw ang D4D engine sa kanila.
November 13th, 2005 03:01 PM #167
In Singapore, they only sell the 2.7 VVTI Fortuner, since AFAIK, D4D engine did not pass their very stringent vehicular emissions standards. Given the prevailing D4D engine problems, I guess this could be a blessing in disguise for them.
November 13th, 2005 05:59 PM #168
pa'no ba 'yan, mag D4D owners...mukhang naging test bed tayo ng Toyota. It doesn't sound good....
November 13th, 2005 06:03 PM #169
so far wala naman problema on our unit, test bed or not we are very satisfied with our innova, its the only auv/mpv worth 1M, kesa naman Sportivo/Adventure na panahon pa ng kopong. no offense to owners.
November 13th, 2005 07:02 PM #170
[QUOTE=jagxtrm]guys, my brother gave me his advice... he has a innova d4d G m/t using petron diesel max (without biodiesel or any additives)...
before u stop the engine (by turning off the ignition), u MUST let the engine idle for at least 1 minute (off ang aircon para walang load) para daw mag slow down yng turbine ng turbo...
ang reason daw is to 'release' yng na-build up na pressure sa intake after running the engine at 1,800 rpm or more. also it will prevent early breakdown ng pipes due to 'unreleased' pressure. i think D4D turbo can generate up to 10 to 12 psi of pressure sa intake after running 80 kph or more.
[QUOTE]
Actually this is true as per the Owners Manual. It is highly advised to let your engine run for 1min before turning it off specially after hiway driving. So far I have no problems with my D4D Fortuner. Starting in the morning 1 click lang but need to warm up. I experience slight knocking for first 200-300 meters. I tried Petron and Shell. My mileage seems higher using Shell diesel although napansin ko na medyo matapang ang exhaust sa Shell (ave 8.7kpl). Sa presyo ng diesel ngayon, I stuck with Shell.
Still atop & adored. The 221 Mazda MX-5 is Still On Top, According to Consumer Reports Sent...
2016 Mazda MX-5 Miata
