Results 781 to 790 of 2023
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 23rd, 2006 04:13 PM #781larshell, ot reply: na timing ko kasi a few other meetings with the chemrez meeting kaya siniksik ko na lang. Nope, am based in Cebu, and took the cheapest flight.
Para di na tayo OT, if you look at my chart on page 39 of this thread, I was getting 7 and 8km/liter without BD, then with BD, puro 8 and 9km/liter na. On October 10, the fuel economy deteriorated but that was because the car went back and forth into my company motorpool and toyota casa as well. But after the choking problem disappeared, tuloy ang improved economy. So with the improved fuel economy, bawi na ang BD expense. BD's lubricity effect is a much bigger, but unnoticed benefit. Para sa akin, if the use of BD really improves lubricity and helps minimize the choking problem, then its worth its money in gold for that peace of mind.
Again, I reiterate my inquiry, together with jaeger, if there were any other innova owners who used BD but still encountered the choking problem? So far, ako pa lang ang nagreport na nagchoke ang innova ko right after using BD, but ako rin nagreport nawala ang choking problem ko without any need to change the fuel pump.
Parang ganito, assume the fuel pump as a human heart. If the main way to correct it is open heart surgery, and you find out some chinese medicine (biodiesel) seems to have unclogging (lubricating) effect that may defer the surgery(replacement), would you try it? (actually, this metaphor if looked at by itself, is true, by the way, there really is a chinese medicine that seems to help those with clogged arteries, its called o pe bok bi in chinese, or black/white fungus).Last edited by altec; March 23rd, 2006 at 04:28 PM.
- Jun 2005
- 325
March 23rd, 2006 04:50 PM #782Originally Posted by larshell
o para hindi tayo ma-cite ni howee na OT (sorry bro) :
altec and I, up to today, have this theory that the use of biodiesel will mitigate (lessen likelihood of occurring) your D4D Engine Woe - the choking problem in particular. This is due mainly to biodiesels lubricity benefit = 1% blend yields 32% increase in lubricity para hindi bumigay yung supply pump mo.
When the Phils. adopted Euro III emmission standards (i.e. 0.05% sulfur content) the process of desulfirization practically removed the lubricity elements of petroleum diesel. You have to put this lubricity element back in the form of an additive or something so that your supply pump will not fail.
Since the oil companies e nagtitipid in putting the correct amount of these expensive additives, we end up with a diesel fuel that lacks lubricity. So this is where biodiesel comes into the picture . . . . para hindi mag-shut down yung maselan na supply pump ng ating d4d.
Of course, there are other benefits of BD other than lubricity.
- Sep 2003
- 786
March 23rd, 2006 05:38 PM #783thanks for the info sir larshell, meyron bang validity ang biodiesel? I've got a few liters at home for more than a year already.
March 23rd, 2006 09:50 PM #785Originally Posted by bongliza
- Aug 2003
- 1,251
March 24th, 2006 09:32 AM #786Originally Posted by jaeger
- Jun 2005
- 325
March 24th, 2006 10:14 AM #787Originally Posted by altec
March 24th, 2006 01:26 PM #788Originally Posted by jaeger
- Jun 2005
- 325
March 24th, 2006 02:34 PM #789Yes, you got that right 1.5-li. of BD in a 50-li. tank will be 3% blend and 2.5-li of BD in a 50-li. tank will be 5% blend. There's no hard & fast rule on the use of biodiesel. Just stay anywhere from 0.5% to 5% blend is generally safe.
I think the Phils. will soon have 1% blend available on most pumps - CAMPI already approved this (will not void warranty). Most of Europe are now at minimum 5% biodiesel blend - mandatory for Euro emmission compliance. There are even European countries at 20% blend like the Czech Republic.
- Aug 2003
- 1,251
March 24th, 2006 03:29 PM #790busy road, when you hear the jargons: bd1, that means 1% biodiesel blend. This means for every 50 liters, you put in 500ml. If BD5, that's 5%, if BD20, that's 20%. If BD100, that's pure biodiesel. Some people call pure local biodiesel as CME, or coco methyl ester, in case they get confused why pure biodiesel doesn't contain a single drop of diesel, pero OT na tayo. Please go to the biodiesel rulz thread to discuss biodiesel further.
Jaeger, alam mo, partly successful na tayo, seems there is no one out there yet to claim nag choke d4d nila when they were on bd. So maybe di na tama ang title dito, kasi meron na light at the end of the tunnel?
Traffic!
