Results 451 to 460 of 2023
December 30th, 2005 08:49 PM #451Originally Posted by number001
December 30th, 2005 09:30 PM #452Originally Posted by andre
December 30th, 2005 10:06 PM #453Originally Posted by KCboy
December 31st, 2005 12:47 AM #455
The Toyota D4d failure could be a result of dirty fuel. But fuel quality is beyond Toyota's control so they should address this by modifying their systems to cope with whatever factor is causing it to fail.
Hyundai CRDi's have been here in the local market (albeit through the gray market) a few years longer than Toyota CRDi systems. Yet, there is not much problem with their systems and they still use the same system of fuel delivery in their current CRDi units.
If Toyota really wanted to address the CRDi problem, they should replace those with failed CRDi systems with modified/improved parts rather than replacing them with essentially the same component that failed.
When CMC had a recall of MB100's, that's what they did. Better intakes, better locks, stronger shifters, etc.
December 31st, 2005 12:56 AM #456Originally Posted by apexi_66Signature
December 31st, 2005 01:02 AM #457
Isuzu Trooper iyan malamang. Hindi ba, hindi naman Denso ang gamit ng Nissan at Mitsubishi?
December 31st, 2005 08:22 AM #458
isuzu trooper yan 4 sure...im suffering right now with it.hehehehe. kung alam nila, d kaya yung fuel quality, they should have installed 2 filters...i guess cost cutting kasi since ang innova ay pang masa na car, and yung innova naipit sa kanila since alot of people want to buy the fortuner.
December 31st, 2005 09:09 AM #459
OT
*KCboy
Which model year of the Trooper do you have? Is this the one that Isuzu was selling with a "SkyRoof"?
December 31st, 2005 10:15 AM #460
Mga ka tsikoteers, mukhang may bagong problema na naman lumalabas sa mga Toyota Fortuner. Ano ba yannnnn mga igan : Check this new post from a guy from Thailand:
Toyota Fortuner's had brake problem in Thailand.
Submitted by thaifortuneruser on Sat, 2005-12-31 03:44.
We test Toyota Fortuner with BEISSBARTH brake tester on 6/12/2005 in Bangkok THAILAND.
We found the brake efficiency was 45% (below standrad)
Brake force front axis left 3310 newton right 2870 newton
Rear axis left 1730 newton right 1390 newton
Brake imbalance front axis 13%
Rear axis 19%
ROAD TEST on 5/12 /48 found brake rotor temperature rise
550 degree Centrigrade,brake pad crack , experienced brake fade and must increase pedal Force about 30% to obtain same stop distance.
More information at www.pantip.com/cafe/ratchada
(thai language)
(001)02-2950480-5
Sorry if this massage waste your times.
Yes Yes squeaking sound is heard when shifting only
