Results 181 to 190 of 2023
November 16th, 2005 11:03 AM #182
I went at Toyota Balintawak yesterday to fix my garnish problem and my agent talk to me about the CRDi parts. Good news my agent told me, Thousands of CRDi parts have already arrive and distributed to sub-supplier.They are aware of the problem, i think. I call Toyota QA and there still this one tube na kulang pa sa mga parts.My unit is not included wd the allocation.They also told me that they are expecting this problem wd CRDi w/in 120K ODO reading it so unfortunate daw it happen so early Meaning i only have 120,000km. before my CRDi will have this problem again after they fix my CRDi. Warranty expires at 100,000km. or 3yrs w/c ever come first. Also they told me that in other countries earliest that this problem occur is 20,000km. on ODO reading.
I suggest to all D4d user to use it daily at least if problems occur w/ur D4d under warranty pa and you have another 120,000km to run.
November 16th, 2005 11:12 AM #183
Thanks for the said info.
It looks like my Fortuner pull-out was a blessing in disguise.
November 16th, 2005 11:16 AM #184Originally Posted by larshell
or sell the vehicle kaya lang nakakaawa naman yung buyer and i guess it is up to the seller who knows about this problem to level with the buyer
- Jul 2005
- 499
November 16th, 2005 05:29 PM #185Originally Posted by larshell
re d4d problems, mahirap din kung abutan ka ng engine trouble sa malayo at deserted na lugar. i usually use my car 70km/day, 90% highway driving so i need a durable and worry free engine. also, baka mamaya may makisabay na client sa new car ko tapos ayaw naman mag-start. diyahe na, perwisio pa...
November 16th, 2005 06:41 PM #186
I talked to a friend of mine from Isuzu Philippines Corporation. The same problems occurred with the initial release of the Commonrail Diesel on the Trooper. Injector problems caused several units to malfunction din daw (they attributed it to poor fuel quality). I asked him if, with a different engine displacement, the same injectors can be used. No, daw... I'll have to confirm this with someone from Toyota, but, I guess magka-iba ang fuel injectors and denso pumps ng 2.5G & 3.0V. As, there is still no actual 3.0V owner complaining, I will assume (for now) that the problem is limited to the 2.5G fuel injectors and pumps. But, as someone here suggested, I'll have to be wary of my D-4D engine's behavior and where I go.
November 16th, 2005 07:59 PM #187
it would seem that the problems (as of this date) in the d4d occured mostly on innova owners. Meron na ba isa sa inyo who owns or knows someone who owns a hilux na nagkaproblema na sa d4d?
November 16th, 2005 09:25 PM #188Originally Posted by 111prez
November 16th, 2005 11:08 PM #189Originally Posted by larshell
November 16th, 2005 11:19 PM #190Originally Posted by usokpower
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
