Results 171 to 180 of 2023
November 14th, 2005 03:05 AM #171
is that the reason why they recommend letting the car idle for at least a minute after running at high speeds? to release pressure in the intake? isn't the car engine doing that always, also through the wastegate?
isn't it that the main reason is to let the turbo cool down by using the oil circulating in the turbo's bearings to carry heat away from the turbo? if the oil cooling the turbo bearings kasi get hot, it sort of degrades and will eventually gum up/coke the bearings, eventually destroying the turbo diba?
November 14th, 2005 10:15 AM #172Originally Posted by nugundam93
November 14th, 2005 10:33 AM #173Originally Posted by vicoyski
I agree wd you my problem wd my Innova is not related wd Turbo i also ask my SA just to be sure.
November 14th, 2005 01:57 PM #174Originally Posted by nugundam93
- May 2005
- 269
November 14th, 2005 02:10 PM #175So every D4D has to idle for 1 minute at the gas station before killing the engine & fill up.
November 14th, 2005 03:37 PM #176Originally Posted by andre
- May 2005
- 45
November 14th, 2005 05:24 PM #177Originally Posted by vicoyski
November 14th, 2005 05:36 PM #178Originally Posted by bitoks2004
you get huge gobs of torque down low with the help of a turbo... and in return you must make these small sacrifices to maintain the turbo.
November 14th, 2005 05:36 PM #179Originally Posted by bitoks2004
Hmmm.... Kailangan na ng aircon service niyan innova mo. I have a blackish red innova. Bilad sa...
