Results 131 to 140 of 2023
November 7th, 2005 11:46 PM #131Originally Posted by vicoyski
- Aug 2003
- 9,720
November 8th, 2005 08:03 AM #132let me be the village idiot for today: aside from the annoying hard starts, is the problem really that serious? or are we just taking a cue from this, and anticipating problems in the future? is it because patchup work doesn't really inspire much confidence in any IMV buyer?
of course i do understand that anyone who's about to part with around 800k worth of blood, sweat and tears would rightly expect a perfect ride; isip ko kasi na yes, it would take 2-3 tries to start up, pero baka naman afterwards e ok na sya.
are there any other problems reported, like it choking/stalling while running on the highway and stuff?
no malice or sarcasm intended po ha....i'm just trying to gauge the severity of the problem
November 8th, 2005 08:19 AM #133
Well that's the pain of having diesel equipped vehicles. Maintenance is a pain in the arse not to mention delays and headache. I wouldnt wonder why aircrafts was not designed to run on diesel engines. Imagine if it stalls in the middle of a flight? Tsk Tsk.
November 8th, 2005 09:10 AM #134Originally Posted by badkuk
Last night along QA there is one Hi-lux J Stall and the Hood is up im afraid to stop and check it out baka carjacker kasi e block out pa naman.What i did i stop about 800m away from him for about 5min. I cant resist to check baka kasi may konting trouble lang, mukhang stall engine nga, i can see one is checking the engine and the other one is trying to start the engine.(i can here engine crank)No reg. plate yet.
All this unit is bought BrandNew and wd the faith that no trouble will occur at least for 3-5yrs. or 100T km. mileage.It should be 99.9% Good Working condition.
- Jul 2005
- 499
November 8th, 2005 09:41 AM #135Originally Posted by larshell
- Aug 2003
- 9,720
November 8th, 2005 11:14 AM #136*gasp* lagot ang IMV project ng toyota kung ganun. tatlong modelo kaagad ang tinamaan! on the upside, sabay sabay din maayos once they address the problem
are we seeing the same trend in Malaysia/Thailand/Indonesia?
November 8th, 2005 11:16 AM #137
i guess denso should check its parts really well since ito yung OEM na supply pump para sa 2KD engine. actually di talaga masasagot ng toyota yan na kung papalitan yung supply pump ng bago ok na. maybe its because of the 'defective' supply pump batch that denso sent to toyota? so what toyota phils. need to do is to relay this problem to denso kasi sila lang makakasagot kung whats really wrong with some of their supply pumps.
November 8th, 2005 11:20 AM #138Originally Posted by beebs
November 8th, 2005 11:00 PM #139
Denso had cases before related to fuel systems. As it turned out, additives used by local petroleum companies affect the system. Don't know about this one though.
- Oct 2005
- 317
Suzuki JIMNY [merged threads]
