Results 71 to 80 of 2023
- Jul 2005
- 499
October 23rd, 2005 12:12 AM #71to those who had or having problems with their 2.5 d4ds, can you guys post as to where/what gas station you usually fill up? baka kasi may halong tubig yung kinarga sa inyo.
also, may nagkaproblema na ba sa 3.0 d4d? thanks.Last edited by beebs; October 23rd, 2005 at 12:14 AM.
October 23rd, 2005 12:24 AM #72
FYI biodiesel compatibility info:
Fiat
No current Alfa Romeo or Fiat engines are compatible for biodiesel use, except in a "minimal percentage" blended with conventional diesel fuel - up to 5%. Use of any higher-percentage blend will invalidate warranties.
Ford
None of Ford's range of diesel engines are fully biodiesel-compatible without modifications. Using a pure blend of biodiesel/RME will invalidate a warranty. However, a blend of up to 5% RME can be used without affecting warranty cover.
Honda
The Isuzu-supplied engine fitted to the new Civic Diesel runs on diesel fuel that meets EN590 standards. Use of any other diesel fuel will invalidate a warranty. However, a blend of up to 5% biodiesel/RME is acceptable, according to Honda, although Isuzu hasn't tested it.
Hyundai
No diesel engines currently offered by Hyundai are biodiesel-compatible - the seals in the high-pressure fuel pump are not suitable.
Kia
Kia's technical department in Korea sees no real reason why the 2.9 TD engine fitted in the Sedona shouldn't run on biodiesel (refined to meet the right standards and octane rating), but have not carried out any research and testing with biofuels, and do not warrant the engine for their use.
Land Rover
No information available as yet - call Customer Services and quote engine code.
Mazda
The diesel engines fitted to Mazda models are not biodiesel compatible, and use of any such fuels will invalidate a warranty.
Mercedes-Benz
Mercedes-Benz does not warrant its diesel engines (apart from a very small number of units fitted in German taxis) for biodiesel/RME use.
MG Rover
The diesel engines offered by MG Rover are not compatible for biodiesel use, except in concentrations of up to 5%. Use of fuel with a stronger blend will invalidate a warranty.
Mitsubishi
Mitsubishi has not done any testing with biodiesel in its diesel engines, so any problems arising from its use would not be covered under warranty.
Nissan
Bosch, suppliers of Nissan's diesel engines, say that these engines will function correctly but there will be premature engine wear and any damage thought to be caused by biodiesel will not be covered by Nissan's warranty. Nissan Germany is, apparently, "not actively discouraging" biodiesel use, but this is still under review here. It's an at-your-own-risk scenario.
Peugeot
Both the HDI and non-HDI diesels in the current range are compatible to run on biodiesel - if the fuel is certified to meet the same British standards as 'normal' diesel fuel and comes from an accredited source. Use of non-accredited fuels, however, will invalidate warranties; Peugeot suggests that low-grade fuels can cause problems with lubrication, especially in the high-pressure HDI systems.
Renault
No information available as yet - call Customer Services and quote your engine code.
Saab
October 23rd, 2005 12:24 AM #73
Seat
Until mid-2004, the Volkswagen Group warranted its diesel engines to run on biodiesel (from an accredited source and conforming to the DIN 51606 standard), but concerns over the sensitivity of the latest-generation Pumpe-Duse and piezo-injection fuel injection systems and the quality of the biodiesel fuels available have resulted in a change of policy. It now only warrants its diesel engines for a 5 percent blend. Owners of older VW Group diesels may find their cars can run on biodiesel - but must call their relevant customer services department and quote an engine code to check this for certain.
Skoda
Suzuki
No information available as yet - consult Customer Services and quote engine number.
Toyota
Toyota does not recommend the use of biodiesel or RME, either in pure form or in a blend, claiming that it affects engine reliability - especially the fuel pressure pump. Any engine damage caused by the use of biodiesel would not be covered under warranty.
Vauxhall
Vauxhall/Opel does not recommend the use of biodiesel/RME without modifications to the standard engine; use of such fuels will invalidate a warranty.
Volkswagen
Volvo
The current range of diesel engines, including the latest D5 diesels, are only warranted for a 5% blend of biodiesel/RME, but some of the recently discontinued diesel units fitted in the larger models are fully biodiesel-compatible. However, Volvo stresses that you should ring its Customer Services and check your engine code before using any alternative fuels, as by no means all these engines are suitable for biofuel use.
http://www.channel4.com/4car/buying...iofuels-10.html
Tsikot Member Rank 3
- Sep 2003
- 786
October 23rd, 2005 11:13 AM #75Based from Bluebimmer facts, therefore... most manfacturers don't recommend the use of biodiesel. mmm so How is it in Europe. Don't we use the same Engines as them?
October 23rd, 2005 07:31 PM #76Originally Posted by cary168
our clean air act is only up to euro 1 and 2 (at best) compliant.
this is just the same with our fellow SEA neighbors... around 500 ppm of sulfur for diesel. none of our neighbors have yet to implement a lower ppm figure (though they plan a 10ppm for 2010).
this will entail huge refinery upgrades by the way.
October 26th, 2005 02:58 PM #77Originally Posted by mazdamazda
October 26th, 2005 03:28 PM #78
AFAIK biodiesel use only benefits old diesel engines with minimal modifications (change of fuel line hoses for example). Sa mga bagong engines they need a more refined diesel fuel kaya biodiesel is not really recommended on them.
October 26th, 2005 11:42 PM #79Originally Posted by Innova G
- Aug 2003
- 9,720
October 27th, 2005 10:08 AM #80jim:AFAIK biodiesel use only benefits old diesel engines with minimal modifications (change of fuel line hoses for example). Sa mga bagong engines they need a more refined diesel fuel kaya biodiesel is not really recommended on them.
