Results 31 to 40 of 2023
- Aug 2003
- 9,720
October 20th, 2005 04:52 PM #31ang trend ngayon for diesel engines is puro CRDi na...so this problem shouldn't be specific to D4Ds per se. it's a problem that all diesel cars will have to deal with sooner or later
ironic though...nagpasa tayo ng clean air act, pero diesel natin marumi
October 20th, 2005 04:54 PM #32Originally Posted by larshell
Tsikot Member Rank 3
- Aug 2003
- 1,251
October 20th, 2005 05:07 PM #33I was one of those who mentioned of the innova choking problems over at the biodiesel rulez thread here. I did mention that in my biodiesel fuel economy results thread but in kotse.com site.
At the cold start, the car wont maintain its idling, namamatay, you have to rev it high for a while or else mamatay ang makina. When its warm, wala ang problema. I've been using 1% estrol for almost 2,000km when it happened. I thought it had something to do with my findings with contaminated biodiesel. But before I was able to bring it in to the casa, I had the fuel filter checked by my inhouse motorpool, kasi takot ako na pagmaymakita sa casa related to biodiesel, baka ma void ang warranty. When my chief mechanic inspected the filter, he noticed it was loose, and may have allowed air into the system. He continued to check the filter and found it clean. Inspected the fuel that passes through the filter and found it clear. Reinstalled the primary spin on fuel filter and tightened it, and nawala ang problema.
When I mentioned it at the biodiesel thread, may nagcomment di kaya dahil nalinis ang filter kaya nawala ang palyado, rather than the loose filter? Kasi nag comment din ako din naman ginalaw ang filter, bakit lumuwag? So just this week, I had my innova undergo the 5,000 pms. I specifically asked the service advisor to clean out my fuel tank and inspect it. At this time, no symptoms at all of the palyado, but I did mention it to the service advisor na matagal ko na kilala, since my ae92 corolla days. When he released my innova, he reported the liquid diesel to be clear, and the bottom of the tank to be clean. In effect, he gave a clean bill of health on my unit. He also knows of my use of biodiesel and he gave me the go signal before I used it.
One of the reason why I was concerned was due to my experience on contaminated biodiesel, which caused me to replace my fuel filter priming pump on my kia sedona. And this has affected several of my trucks. Now, I know how to distinguish the contaminated biodiesel and we now inspect before we mix it into our diesel.
October 20th, 2005 08:37 PM #34
"The all-new 2KD-FTV four-cylinder diesel engine delivers top class fuel efficiency with extended maintenance periods. This latest technology diesel engine from Toyota has a high-pressure common rail direct fuel injection system and is fitted with a compact, high efficiency turbo charger. A range of electronic controls, including a drive-by-wire throttle system, assist in optimising engine power output, fuel efficiency, and emissions. The advanced controls also contribute to lower combustion noise and improved torque at low engine speeds."
Excerpt from a D4D review. So, this is all crap? Is anyone aware of same problems with D4D-equipped HiLux? Do they have same problems, too?
- Jul 2005
- 499
October 20th, 2005 10:09 PM #35larshell, number 15 ka sa mga nagreklamo sa dealer mo? medyo alarming ang bilang considering maraming dealers ang toyota. multiply 15 by the number of dealers eh hindi biro yun. hay naku. my diesel adventure has 90k kms sa odo and not once pumalya ito. i know toyota has a 100k kms/3 year warranty on their engines. i appreciate the engine warranty, ayoko lang ng abala. that's why i'm purchasing a new car dahil ayoko ng frequent maintenance.
- Oct 2005
- 123
October 20th, 2005 10:53 PM #37Mga Innova peeps..
My INNOVA G Diesel Variant was brought by my brother a while ago at Marikina
Service Station. My 15k PMS was also done at the said service station. Prior
to
the 15K PMS, we already have complaints that after several full tanks of
diesel
fuel from PETRON and mixing it with ESTROL Biodiesel (5% and 1%), the engine
begins to experience the following:
1. The engine often dies after starting it. This is true during cold startup
(mornings and after several hours of being parked). This is sometimes called
by
users - pumapalya o na-chochoke. Kelanagn mo apakan yung gas pedal or rev up.
the engine.
2. Sometimes during shifting gears, especially on slow speed (2nd gear) parang
kakadyot ung makina o malulunod (has the tendency to stop) pag hindi mo agad
inapakan ung gas pedal.
3. Sometimes, I feel that the engine is loosing power. Although my top speed
is
not affected, the behavior of the engine sa arangkadahan or during normal
speed
is not the same. sometimes I do need to drive hard. But I observed that my
fuel
consumption is still the same. 9.5-10.5 KM/L pa rin. I am now using Shell
Diesel.
All of these symptoms were relayed by my brother sa toyota mechanic sa
Marikina.
Toyota diagnosed again our unit by using their laptop to get into the unit's
engine statistics. My brother also relayed the possibility of the fuel filter
being clogged and maybe it just need to be adjusted. However, toyota did not
attempt to take a look. They are satisfied with the results being shown by the
engine at their laptop. The other bad news is, they still have to report the
said event either at planta or at Cubao. They instructed my brother that they
will contact us again for the next visit. This time at cubao. I am planning to
bring my unit at P. Tamo or Makati this Saturday for a second opinion. These
stations I believe are independent and have their own pool of expert mechanics
and management that can decide immediately and do not depend on other
stations.
Since I am not the only one who have experienced such behavior, (others are
just using pure diesel without additives or biodiesel) maybe we could organize
a body or at least help each other to get the attention of Toyota. I believe
that the D4d engine is not that bad since it has been released before in other
countries. There might just be an adjustment with our engines. Lets push
Toyota
to work on this issue. Toyota must have a fixed for this issue, better yet
fixed this issue so that our engine can use and benefit from biodiesel.
October 20th, 2005 11:41 PM #38
Try to stop using additives and see if performance will improve. Sensitive kasi sa pressure and injection pump system. Additives could have been affecting the consistency of the fuel. It can also affect the timing of the injectors causing a delay in delivery and thus loss of power.
October 21st, 2005 12:27 AM #39
kung minsan mahirap din bumili kagad ng bagong technology, nagiging guinea pig ka pa.
Tsikot Member Rank 5
- 3,144
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
