Results 1 to 6 of 6
- Sep 2011
- 3
September 5th, 2011 02:34 PM #2
help those who would like to help. what is your fuel delivery type? what is your ignition type? does it crank normally? what is the mileage? what was the last thing done to it? when does the symptom happen-time of day, climate, altitude, engine temperature? give as much details. don't be stingy with the needed information if you need help
- 52,724
September 5th, 2011 06:36 PM #3may i ask, how long have you had this car? did you recently put in a different type of fuel? some older EFIs have cold starting problems with e10 fuels..
more info, pls..
- Sep 2011
- 3
September 6th, 2011 07:12 AM #4Thanks guys. Sorry guys but not that technical with engine. here are some info that I know.
- Corona Model 1996
- EFI type engine
- had the car for around 2 years
- Mileage: 201260
- did not change fuel type. Still using shell premium (should I change to unleaded)
- hard start normally happens during the morning. When I left my card overnight.
- my Battery is fairly new 1 yr and 5 months.
- last thing I did was when we asked the mechanic to change the ignition coil as it was wet when I had the engine wash. Afterthat hard stating happenned.
- We tried to open the distributor and saw small trace of oil (is this bad already) and for distributor replacement already? how much is a distributor assembly for this type of car?
- So far (past 2 days) do not experience hard starting. I just replaced the EFI & starter relay
September 6th, 2011 08:22 AM #5
- Sep 2011
- 3
September 7th, 2011 07:33 AM #6Thanks. Will the contact cleaner solution also help. I saw one at handyman store?
What vehicle and what's your budget?
